2001 .5 S4 Stage 2+ 6 speed
Clean 2001.5 Audi S4 with about 300hp. I have done everything that is preventative maintenance to this point. I have a detailed log of everything with dates and mileage as well as a Carfax upon request. I have $10K in this car from date of purchase. Lets get to all the goodies and maintenance.
188k miles as of today.
Maintenance
K03's Rebuilt
Timing belt replaced
Timing tensioner gasket replaced
Water pump replaced
Thermostat replaced
Valve cover gasket replaced
Coolant temp sensor
Oil pressure sensor
Ceramic Brakes installed
Yokohama 580 tires all around, warrantied, free rotations, flat repair and replacements.
Aux water pump replaced
Spider hose with custom 200psi hose replaced
New NGK Spark plugs
New Oem O2 sensors
New Continental serpentine belt
New Battery as of 2015 warrantied
New hose clamps(boost leak prevention)
Coolant flush with Heater core flush
Power steering flush.
New 710N diver valves
Upgrades
Engine mounts upgraded
Transmission mounts upgraded
Drilled slotted rotors
JHM short shift kit
Silicon hose kit
SSAC Twin 2 Exhaust with down pipes
Unitronic Stage 2 tune 20lb boost
Boost Gauge
Code matching painted Y pipe
Probably more that I can't think of.
Bad
Central locking pump died, haven't gotten a chance to fix it yet. Might be fixed by time of sale.
Manual boost controller was cheap so boost has fluctuations between 16-20 psi sometimes.\
Wheel bearing on the passenger side started making noise a few days ago, this is the reason I dropped the price.
Call or text me for more information have plenty more pics of all the work Ive done, 402-706-9935
A previous person requested a video of the car at idle, 4k hold, exhaust, shifting through gears and a 2nd gear pull so you can see it here.
https://www.youtube.com/watch?v=y9BhLIicuR4
List Date: 2/17/2016
For more info, click here to view the original listing: 2001 .5 S4 Stage 2+ 6 speed
This item is no longer available.
