Results 1 to 24 of 24
    Veteran Member Three Rings mosnet99's Avatar
    Oct 10 2015
    2004 USP 1.8T, 1993 Jeep Cherokee Country
    Detroit, MI
    Lightbulb Is 75kg or 165 lbs really THAT big of a difference?
    I'm trying to decide which is better between b5 and b6 and upon my research I've found pages and pages of rave reviews of how nimble and better handling the B5 is. I also noticed there IS a difference in weight between a B6 FWD and Quattro, but not a weight difference between FWD and Quattro in a B5?? My question is if a b6 Quattro is 3400lbs and a B5 Quattro is 3241lbs, is 165 lbs really THAT much of a difference to make a car worlds better in handling and racing?
    Misfiring 2004 1.8TQ USP, CX Racing FMIC, Hybrid K04, Milltek HFC
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    There is a weight difference in the b5 FWD and Quattro
    Oct 10 2015
    Detroit, MI
    Quote Originally Posted by MarcRogers View Post
    The manual says 3241 regardless of FWD or Quattro.
    Sent from my LG-H811 using Tapatalk
    Jan 18 2016
    PA
    FWD-2579lbs
    Quattro-2899
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    165 pounds in racing? Yes.
    But you shouldn't be racing an Audi B5 or B6. They're what, 11-17 year old cars?
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Dec 09 2015
    neither here nor there
    FWD-2579lbs
    Quattro-2899
    Yea, add about 400lbs to both of those
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Quote Originally Posted by Kronprinz View Post
    Lols. I wish my car weighed 2900
    Oct 10 2015
    Detroit, MI
    Quote Originally Posted by JDillon15 View Post
    I'd be surprised if there are any members on here that have stayed completely stock....and you're telling me nobody races these cars?
    Dec 09 2015
    So one should only race cars that are 10 years old or newer
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    I have a friend who swears every pound counts. I for one couldn't care less and have over 150lbs of random shit in my car at all times. Mostly tools and audio stuff. I personally think 160 is negligible, but I can feel a difference with two lardo's in my car adding about 400lbs, so it does do something, but spread throughout the car I'd imagine it would be better/not really noticeable. I wouldn't say my b5 is a nimble track machine and I'd assume a b6 is not either.
    With a proper suspension setup I wouldn't imagine there's much difference. My advice for either is get the biggest rear sway you can buy and reinforce it however you can. I have oversteer with mine and it's fantastic.
    Oct 10 2015
    Detroit, MI
    So basically we're talking about a 100lbs difference when conparing B5 & B6 Quattro. Still don't get why everyone says the B5 is so "nimble" when the B6 has better suspension geometry and only an INCH longer & wider.
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    Quote Originally Posted by mosnet99 View Post
    You can look at numbers and say well there is only this much difference, it couldn't be that noticeable right? But then once you actually drive the car you can feel every single little difference. As a driver the B6 is slower, uglier, fatter, rounder, and over all worse. But a B6 quattro is still better then a b5 FWD
    How does the B6 have better suspension geometry? From what I remember its the same set up two control arms up top and two down below.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Nov 03 2011
    All Over!
    Wrath, the B6 rear suspension set-up is more sophisticated than that of the B5. The B6 FWD rear is also independent, same as on the Quattro version, unlike on the B5 FWD, which runs a torsion beam at the rear, carried over from the B4 Audi 80 / 90 range.
    Last edited by Nollywood; 02-17-2016 at 07:26 PM. Reason: Typographical error, "runs" spelt as "rubs".
    1986 Type 85 Audi 90 quattro
    Dec 09 2015
    Quote Originally Posted by Wrath And Tears View Post
    The a4 gets bigger and uglier every time a new body style comes out. I hate it.
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    You don't know what you are talking about.
    Veteran Member Three Rings LA4's Avatar
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    Bigger maybe.
    But in the looks department B7 > B6 every day of the week.
    1998.5 A4 Quattro 1.8TQM AEB
    Stage 1 GIAC, 710N DV, ECS Snub Mount, ECS SS Brake Lines, A8 Rotors, Bilstein Sports/H&R Springs
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by B-Time View Post
    I guess, how are you guys defining "race car"? Are we talking one car vs another or on a track?
    here's how I see it, if you want to modify the car, drive it aggressively and enjoy the car, who cares how old it is? You just want to maintain it. My last two cars have had over 100k on them and both were tuned. I just don't know that I would go out and try racing other cars. I tuned the car for my own enjoyment, not to get beat by all of the significantly faster other cars out there.
    I guess I'm also a little confused by what the OP is trying to do. You just looking for something that handles well? Handling can be changed significantly in your suspension set up. If you're looking for speed, I would compare times rather than weight.
    Oct 10 2015
    Detroit, MI
    I want to start off modding for my own enjoyment then as time goes on and mods get bigger having the option to race it. The USP B6 is a lot better than a regular one that's the only reason I considered it. Then 6 speed put me over the edge.
    May 03 2009
    East
    Wheel to wheel racing on a track. I've raced one and it was a blast. Very easy to modulate slip angle.
    Jul 11 2014
    Chicago, IL
    Sure. And I can see that being a lot of fun as well. I don't know that I would buy either of these cars to purely race then, but that's a matter of opinion.
    May 03 2009
    East
    Your opinion may be swayed if you sat in a gutted and caged one.
    Jul 11 2014
    Chicago, IL
    It very well could be.
    Jul 07 2009
    Socal/IE
    So a tune makes it a race car to you?
    Op is talking a car to build not a tune from a bankrupt company
    Apr 03 2014
    17 GTI Sport
    Quote Originally Posted by tar View Post
    Who are you responding to? The only person to mention a tune is JDillon and he's on the B5/B6 is not a race car team... also no one mentions a tune from a company so how do you know this non-named company is bankrupt? What kind of drugs are you on and where can I get some. That or learn how to quote a post. Forums have been around for over 25 years now, so let's get with the 21st Century and learn to internets.
    Wrath, the B6 rear suspension set-up is more sophisticated than that of the B5. The B6 FWD rear is also independent, same as on the Quattro version, unlike on the B5 FWD, which rubs a torsion beam at the rear, carried over from the B4 Audi 80 / 90 range.
    I was more interested in what it was that they changed to make the geometry more advanced. I know each generation of the B gets improved, but from visually looking at B5/B6/B7/B8 suspension set ups they look more or less the same two control arms up top and two down below. These 4 control arms are used to create a 3D axis something something something something (don't quite remember the technical jargon). But more or less what it means is that the setup of the control arms is what is used to create the suspension geometry (right? or do I have that wrong?). Since the setup hasn't changed I am simply wondering what they did to make the suspension geometry more advance. If it is simply that the parts became more sophisticated allowing Audi to push the envelope or whatever, that makes sense.
