Results 1 to 12 of 12
    Mar 11 2012
    Audi A5
    Ventura, CA
    A4 Exhaust on A5
    I'm currently looking at buying a new exhaust for my B8 A5 2.0T and I found a used APR single exit turbo back from an A4. I had read on the forums that minor modification allow me to use this exhaust with no problem. HOWEVER when I contacted APR they said it absolutely would not fit and that because they were two completely different vehicles there was no way to make it fit so I had to back out of the deal for the exhaust. After doing more research, almost everything is saying that it SHOULD work.
    The reason that i'm posting this is to try and locate someone that has actually done this and knows definitively if it is actually possible and if so how much work and what needs to be done to make it happen. Thanks!
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    With enough custom work you should be able to make anything fit anything. I don't remember where I read this but I think i recall reading its only a matter of where the downpipe meets the exhaust either needs to be expanded or narrowed and it wasn't a very complicated mod. I'm sure APR would tell you otherwise because they don't make any money from you buying used and they don't want to be liable for telling you it works even if its modified since it could be up to how good the exhaust shop is. That being said, unless you're saving a LOT of money I'm not sure its worth the risk.
    If you're looking for an A5 exhaust it looks like there's a dual exit single tip stasis exhaust in the classifieds for only $800 and it appears to be new old stock. You should pick it up before i convince myself that i need it :D
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Mar 11 2012
    Audi A5
    Ventura, CA
    Quote Originally Posted by Sweep View Post
    Really looking for the full turboback and I haven't heard the greatest things about the stasis exhaust(drone).
    Veteran Member Three Rings ParadigmTony's Avatar
    Apr 02 2015
    Rochester NY
    APR is just not going on record stating anything. Plus they wanna sell new parts. Cant blame them. It will work. All the way up to the rear, you will need to do a bit of modification, but it by no means is a deal breaker. Most exhaust, or tuners should be able to do it under an hours labor.
    //B8 A5 // 6MT DSB Pearl // Roc-Euro // APR // AWE // BBS // Bridgestone // StopTech // // K04/Stage 3v3/FMIC/Roc-Euro Intake/Test pipe-AWE touring/100oct life/19x10 CI-R/RE71R/ST60 BBK //
    Mar 11 2012
    Audi A5
    Ventura, CA
    Where did you see this?
    Sep 05 2014
    Quote Originally Posted by Sauci View Post
    Panjo A5 classifieds
    Sent from my XT1575 using Tapatalk
    Ken
    2021 Q5e Prestige
    District Green
    Sep 05 2014
    Let me know if you end up picking it up
    Ken
    2021 Q5e Prestige
    District Green
    Mar 11 2012
    Audi A5
    Ventura, CA
    I'm not finding it on there.
    Sep 05 2014
    http://www.panjo.com/buy/b8-2-0t-sta...36827?index=10
    Ken
    2021 Q5e Prestige
    District Green
    Mar 11 2012
    Audi A5
    Ventura, CA
    Mmmm. I actually hit that guy up on audiworld. Still waiting on a response.
    Sep 05 2014
    He listed a phone number on the panjo listing, try texting him
    Ken
    2021 Q5e Prestige
    District Green
    Mar 11 2012
    Audi A5
    Ventura, CA
    A4 Exhaust on A5
    He sold it. Bummer
