I'm getting ready to replace the motor mounts in my A4 B7 Quattro Cabrio and from a good DIY found here, it looks like it's a lot easier to loosen the subframe brackets from below to allow additional room for mount removal. I've also found that the bolts securing the brackets are TTY. That being the case, I'd like to order the bolts in advance, but I've found a few discrepancies as to the number and size of the bolts. This is a 2009 A4 Quattro Cabrio, which is a carry over B7 from the 2008 model year. No vendor I've found (other than Audi) sells both of the part numbers below, but I've found both listed as bolts separately from vendors. N90956803 (longer) and N90663002 (shorter). Some posts have said two bolts each side, where another has said three. One post said all three were the same, using N90956803, and another post saying theirs had both shorter and longer bolts. Since the bolts aren't cheap, I don't want to order several of each to be sure i have them, with some left over. Anyone know for sure which is the safe number and part number for bolts needed? I'd prefer to replace the TTY bolts.
thanks,
