Results 1 to 12 of 12
    Oct 21 2005
    y
    Sachs Type M 240
    Where can I buy a Sachs Type M 240?
    Are they generic or specific models?
    Does CM modify the PP or do they just paint them unmodified? Fx400 specific.
    Oct 21 2005
    y
    No one?
    What other pressure plates bolt on the fx400 flywheel?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I dont think anyone knows what you are talking about. I love researching stuff, particularly audi stuff, but have no idea what a sach type m 240 is. And I don't really feel like doing all your ground work for you at the moment. Have you tried making a phone call or email to sachs?
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Quote Originally Posted by redline380 View Post
    The pressure plate that comes with the CM fx400 is a Sachs m240. It says it right on it. What CM does with it besides paint it white, who knows? Maybe Mike knows.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Oct 21 2005
    y
    Quote Originally Posted by Avant Nate View Post
    It looks like it has several different versions for different cars. Also been googling and nothing comes up. Couldn't find any part number on any of the fx400 pics.
    Would you guys know if a stock s4 / b5b7 rs4 / 7a pp have the same bolt pattern and offset as the fx400 (sachs 240)? Or southbend, clutchnet etc fit the fx400 flywheel?
    I'm trying to piece together a cheap clutch. I do know the ebay s4 6 puck disc works with the fx400 pp and fw. On my 3rd ebay disc now.
    Dont want to spend another $600++ on clutch that barely lasts 10k miles.
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Why are you burning through clutches that fast?
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Oct 21 2005
    y
    Quote Originally Posted by nynoah View Post
    Theory is mostly because stop and go traffic. City. Also seems to be in lower range of norm for fx400 6puck lifespan.
    Rarely launch it. Maybe 10-20 launches per disc. Crank seal isnt leaking. Also replace the discs as soon as it barely starts sliding.
    Discs cost $50-60 each didn't even bother to resurface anything. Still on the orig fx400 fw and pp. As expected, each disc lasted less than the previous. PP is paper thin already lol.
    Jan 16 2006
    LA CA
    perhaps you should look into getting a b7 RS4 setup
    Jun 30 2008
    Erie, Pennsylvania
    Yeah, I was going to suggest a B7 RS4 setup, too. I just bought one myself for $140-something shipped from RockAuto (just in case they disappear at that price). I'm on the lookout for a flywheel to go with it, and my first choice is a Clutchmasters 240mm unit - because they are one of the heavier solid flywheels available at 19lbs.
    Oct 21 2005
    y
    The bolt patterns the same? Just need to change offset?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Someone should really do some groundwork and see if audi ever offered a 6 bolt 240mm flywheel so we can run OE flywheels. I doubt they did, but it is worth a shot.
    2000 S4- Working?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Boom. 337 GTI flywheel is 6 bolt and 240mm disc.
    Go to work walky.
    2000 S4- Working?
