I think AEM makes a good replacement filter for either if needed (I had the part number somewhere, but can't seem to find it). I didn't have any issues with the CTS filter, and I think the key is keeping it oiled. It may not be the best quality, but I have a hard time believing the Roc-Euro is a lot better. Either way, there are several replacement options for later down the road.
Having installed both, the CTS does do a better job with the tube clearing the coolant line, but overall fitment is so-so because I had issues with the heat shield (I had to modify the mounting points). With that said, as mentioned above and even with the fitment issues I had, the mounting solution for the CTS is far superior to the Roc-Euro both for the heat shield and breather filter.
Both are nearly identical in terms of performance. After going through several intake options, I'd personally recommend splurging on the ECS, but I understand it may not be for everyone.
