Originally Posted by
Rocket Tech
Hey guys - I've read that Audi paint tends to be pretty hard. I've got a 2015 sepang blue s5 that has a bunch of tiny swirl marks. It's actually not bad but it bothered me enough to try and do some correction. We had a pretty bad wind storm come through and I think a bunch of branches/dirt got blown across the car because there was an insane amount of really light scratches all over the car.
I have Brilliant Black but without seeing pics of yours I'll assume it's moderately hacked up. Overall, Audi paint is moderately tough but not hard like an F150 or a Vette. That said, it's clear coat responds better to a quality MicroFiber cutting pad vs a foam pad. Either will work but you just need to lean into it a bit more with foam. Orange is light to moderate and that's all you'll need. Unless you're compounding out real crap issues you won't need yellow. Once you have it fairly well corrected foam will work fine though.
I have a torq 10fx and have the chemical guys v series compounds. I started with orange and v36 but it didn't seem to do much at all. Stepped it up all the way to v32 at which point I could see correction happening but there was still a fair bit of swirls. I thought maybe the v32 wasn't breaking down enough to give a mirror finish so I did a 4 step correction - orange/v32, orange/v34, white/v36, and white/v38. I'm sure the last few steps didn't do much other than pull out any hazing I created with the heavier compounds.
CG makes some good products but the V-Series IMO is a bit over rated. Honestly, Meguiar's OTC Ultimate Series is a lot better and easier to use. You might not even need
Ultimate Compound but if you do, hit it with an orange pad and then follow it with
Ultimate Polish with a white pad. You'll need 5-6 orange and 4-5 white for your car.
Here's what can be done with U.C. and an Orange Pad:
Before and
After shown: This is on our 10yr old minivan with over 100k abusive miles on it. Still looks like new.
Again, you might not even need to hit it with compound if it doesn't look as bad as the above. Another great option is
HDAdapt and
HDSpeed. Adapt is a compound that finishes smooth, even with an orange pad and
HDSpeed is a polish that finishes and seals up the paint. Best used with a green pad. I hit the above vehicle with
HDSpeed and a green pad after I did the above and the results were fantastic.
Here are those
results: Hood shot reflecting my garage and door. One inside the other outside.
I've heard microfiber black/orange pads with menzerna sf400(?) is a popular combo. Was it that I wasn't using a heavy enough pad/compound for the paint?
Again, yes on Microfiber for Audi paint. Keep it simple and buy (3) two packs and change them out often. I would really only use MF though if you need to compound the car. Pics will give me an idea if you need to. Menzerma is good stuff too. They developed the SF line up years back for MBZ, BMW and Audi paints. I like to finish with SF4500 which is one step finer than Meguiar's Ultimate Polish. It's a better nano-cut technology that really brings out the Audi Paint to a brilliant shine. Seal it up with
Menzerma Powerlock and you're golden. If you're really a nut like me put two coats of
ChemGuys Blacklight on it first though. The depth will be outstanding.
See my S4 here: I sealed it up with
Collinite #845 after this as we were going into winter.
Hope all the above helps. Post pics if you've got them. Once polished up, again, hit it with some Blacklight and seal her up for a deep smooth flaw free finish. You'll love it and the upkeep is minimal. All in proper washing and drying technique. More so drying really.
Decklid and hood then hood close up: Brilliant Black
