I'm running Unitronic Stage 2, car runs fine but is burning a litre per 500KM (300M)
I recently changed the PCV diaphragm which helped quite a bit with the black smoke when getting on the throttle. With being flagged TD1 I won't get anywhere with the dealership, so no use even trying. So, I'll be looking at doing a motor rebuild. If I'm gonna do the motor, I might as well build it up with aftermarket rods, pistons, and an Integrated Engineering head & intake. With the poor CDN dollar, it's going to cost me a small fortune. If I build the motor is the oil consumption issue going to come back over time?
I've got plans to put an EFR or something on this after building the motor. Want some serious power out of this if I'm going to drop a bunch more money into the car.
How much longer will I be able to drive the car before I risk it blowing up? I'm taking it easy, but it seems my oil consumption is pretty high. Worried about it grenading before I get the motor pulled to build it.
It runs smooth, good idle, decent power, just goes through a serious amount of oil.
Thoughts? Am I running on borrowed time already? Can't see any oil leaks either.
