Results 1 to 2 of 2
Thread: A8 v2 air ride
    Veteran Member Four Rings 1dopea4's Avatar
    Aug 03 2010
    joliet IL
    A8 v2 air ride
    Hey guys, just had a question.. Has anyone tried to use stock bags with a aftermarket air management like v2 or e level? Do the stock bags not go low enough? I saw a crashed a8(d3) and the front end was damn near on the ground. Why couldn't we convert the 1/8inch lines I think it has to 1/4 inch air line to go into the v2 management. And cap off the stock air so no check engine lights or any other lights.. I plan on getting a a8 soon, trading in my mkv r32. I just want a more subtle ride.
    Aug 03 2010
    joliet IL
    So doing some more research, the a8 uses sensors to detect height so although it will be possible to manage air through the v2 controller it will still throw a code unless you can use vagcom to disable air ride all together.
