Results 1 to 11 of 11
    May 12 2015
    Homeless
    Question Observation in coilovers and suspension before i buy
    hey guys, ok so im having a freaking hard time reading and deciding, casue is a $hit load of money and ill be super piest if i made a mistake.
    I found this write up and its awesome but i cant find the answer http://www.audizine.com/forum/showth...ipload-of-Pics
    So i have this Audi a4 B7 3.0 TDI quattro and i want to upgrade the suspension, im the third owner and as i was inspecting the car, the control arms are wasted, plus the struts are leaking, so i decided to upgrade the suspension, one dude here on the forum gave me a good tip in a control arm discount on FCP, i got that done, but now i wanna change the coil overs, i found that KW is a good choice, expensive, but good, but here is the question, after i spoke to the provider he told me this model will fit
    http://www.ebay.com/itm/KW-Variant-2...item2305a404e6
    but as you already know, the B7 suspension on the rear has is separated, springs on the inner and struts closer to the wheel.
    Like this
    so i thought you actually need this model
    http://www.ebay.com/itm/391380121216...8501725a8&cp=1
    "as you can see the coils are separated"
    So whats the deal, if i use the first option, i have to remove the stock springs on the rear?.
    Im sorry if i sound like a retarded, but, i need help to fight this retardation :P.
    PS: should i get adjustable upper arms to correct the camber due to new coilovers?
    Im not really a big fan on lowering the car a lot, i love the clearance that this machine has.
    Kind Regards
    Stock Audi A4 B7 V6 3.0 TDI Quattro....
    Jun 17 2013
    jersey city nj
    To be on the real with you. If your spending that type of $$$$$ on coil overs I really suggest you at some http://www.bilsteinus.com/products/p...b16-pss9pss10/ not that KW that you listed aint good. I just wanted you to another option
    May 12 2015
    Homeless
    bilstein was my first option but sadly i have no feedback to support the purchase. :/
    Jun 17 2013
    jersey city nj
    May 12 2015
    Homeless
    thnx for the info, i read those and i found this
    https://store.034motorsport.com/psi-...hlins-ttx.html
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by nachofly View Post
    I couldnt afford those
    Senior Member Three Rings Mlambrecht17's Avatar
    Aug 11 2014
    Minnesota
    Since you already have the control arms done, I don't think you have to do all that work on that write up. I find this video super helpful, it looks pretty easy from what the video shows. I plan on installing coils in the spring http://youtu.be/bXC79Io4UCk
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    Both of the KW V2 kits you listed are the same, same part number. Don't go by the pics always.
    May 12 2015
    Homeless
    yes , that's why i'm confuse, even tho in this case picture are no the same, my question remains the same, can/should you replace the rear shocks with coil overs?
    Veteran Member Four Rings pat_do's Avatar
    Feb 19 2012
    Montreal
    Theyre shit.
    Had them and they bounce like mad
    May 12 2015
    Homeless
    Quote Originally Posted by pat_do View Post
    Theyre shit.
    which one?
