Hey guys,
So this all started after I replaced my thermostat. Sometimes, when the engine is warm, when I start the car and put it in drive the engine shuts off. Now usually I can just throw it in park and start it up like normal but today was different. The car died after throwing it in drive, and when I tried cranking it again, the engine sputtered and could barely stay running on its own. It kept shutting off after 5 seconds of struggling.
This happened 5 or 6 times, then while it was sputtering I mashed the gas and put it in gear. That seemed to do the trick and it ran completely fine from that point on. I was able to drive 20 miles home. Car ran perfectly. Since then I've started it up and its been firing up as it should.
Anyone have any ideas as to what the issue could be or experience this before? I scanned but no codes came up. No CEL. Nada.
I am beginning to think its an issue with the alternator. The car cranks fine, it doesn't struggle. Battery is 2 years old. I took the alternator out to do the thermostat, I was pretty thorough about reinstalling everything including the alternator.
Thoughts?
