Results 1 to 29 of 29
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Cross post: 17Z Pedal Feel Opinions
    Hey everyone, I did a few searches, but couldn't find much.
    I want to get a few opinions from those of you with 17Z's on the pedal feel.
    I recently picked up a set of them and was worried that the pedal feel would be crap. I currently run B5 S4 calipers in the front and stock rears. I had to bleed the brakes about three times before the pedal was okay. Even then, the feel is kinda meh. I'm pretty sure the air is all out because with the car turned off, the pedal firms right up. It feels like there's more pedal travel before the brakes engage.
    I am also on the stock MC and brake booster as well. I have yet to do any ABS recoding with VCDS, but I don't believe that would alleviate the pedal travel.
    Anyways, back on topic. I am kinda hesitant to install the 17Z's because of a few cases that I've read where the pedal feel is crap. I emailed ECS about pedal travel with their Stage 5 kit with 18Z calipers and they said: "We sell a lot of these kits and have never had any complaints about pedal feel. These are designed to retain the OEM pedal feel even though it is a larger caliper. A lot of the customers who purchase these kits use them for the track."
    So I'm getting mixed answers here. I understand how Pascals Law works and how different MC piston and caliper piston areas affect the pedal feel, but I want to hear some firsthand accounts.
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Jul 04 2012
    Woodbridge, VA
    Drive them. They will feel better as they are used. Trust me. Same issues I ran into.
    Feb 09 2013
    WNY
    Quote Originally Posted by vavJETTAw36 View Post
    When you say feel better, is the pedal travel actually improving or perhaps you're just getting used to it?
    Jul 04 2012
    Woodbridge, VA
    Sorry I skimmed and missed some key pieces of info.
    So what I was saying was when I first installed my 17z's, they felt like they needed a lot of pressure to get them to work. I hated it. I bled entire system once more with same results. I got some advice to just drive and bed them. After bedding them they are back to normal feel. Almost oem.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Get rid of those dangerous things asap!!!
    Scrap guy here gives me a good rate so I could prob give you $100 if you send them to me
    Put them on, you wont regret it.
    I have seen some be a little funny at first, but they got happy after a day or two. I think it was just the shims that are stuck to the back of the pads flattening out and getting cozy in their new home.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Feb 09 2013
    WNY
    Quote Originally Posted by zillarob View Post
    Lol. Let me box them up for you right away then!
    I think I'll go ahead with the 17Z's then.
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    i'm not sure if this is relevant but i have 18z calipers and i like them with no pedal feel issues. stops like a dime every time
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    18z are actually better suited the B5's.
    Pedal feel with 17z will be more 'unassisted' than stock. Eg no initial 'bite' when you first touch the pedal, but they will stop well.
    For the aforementioned reason, I wouldn't install 17z again on a B5. To each their own, though.
    Nov 16 2010
    WetSide, WA
    Given the same pad, I doubt most could even feel the difference between 17z and 18z.
    Pad choice makes a way bigger difference than 17z or 18z.
    The 17z/pagids I ran at first had so much initial bite that I put the mystery pads from the junkyard in to calm them down.
    Feb 09 2013
    WNY
    Quote Originally Posted by jaychen View Post
    Yep. 18Z total piston area is slightly smaller than the 17Z.
    My main thing is pedal feel. How much pedal travel would you say there is before the pedal firms up?
    Feb 19 2011
    Earth
    Quote Originally Posted by fR3ZNO View Post
    I don't remember measurements.. enough to know i didn't like the feel and wouldn't do it again.
    I'm sure there will be other people that say different, but i tried 2 or 3 different pads too. They just don't feel assisted.. not a feeling i like in my cars.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    not sure what you mean by assisted? how do the stock brakes feel assisted?
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Feb 19 2011
    Earth
    Quote Originally Posted by audacity View Post
    last time i checked b5's run a brake booster.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    LOL, yeah pretty sure he was referring to vacuum assisted brakes. It would be very difficult to generate enough pressure with your foot alone without an absolutely giant piston
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Nov 16 2010
    WetSide, WA
    I drive quite a few of these cars with all sorts of different setups and have never felt anything like that.
    Well, there was this one time I had the brake booster line off for some diag- that was fkn both feet on the pedal scary!
    I actually think this is a good thing to do for people with the late style booster hose to prepare them for when that thing blows apart Its no joke.
    I think you had some bunk calipers or something else going on there.
    hp2, 17z, 18z, stoptech- they all stop just fine. Some a little better than others.
    My junkyard 17z/v70r rotors and those evil Pagids would just about put you through the windshield if you werent paying attention. Not to mention being the dirtiest pads Ive ever seen in my life. Should have read the Touareg forums before I bought them.
    I threw the mystery junkyard pads that showed up in the calipers in and like them much better.
    I drive a few with Hawk HPS and those are also nice drivers. Will get these on the next go-round.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Interested in windshield shattering pagids....
    2000 S4- Working?
    Nov 16 2010
    WetSide, WA
    Pretty much new.
    Pay for shipping and those nightmares could be yours
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Pretty much new.
    If you are serious PM me. Drop them in a flat rate box and I will check them out come spring!
    2000 S4- Working?
    Nov 16 2010
    WetSide, WA
    Lol, Ill dig them out for you. I hope you have black wheels
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    so they should feel assisted...unless you removed the booster.
    White 07 Q7
    Veteran Member Four Rings Racin2redline's Avatar
    Aug 19 2012
    1997 Yamaha razz 50 (sik)
    Long island
    Quote Originally Posted by redline380 View Post
    lol pagids are notorious for that
    what model ? are they oem compound? my b6 brakes feel like that also with pagid... boy do they dust lol
    Sent from my SM-G900P using Tapatalk
    IG: d3bel1o
    Aug 31 2014
    2002 stage 3 a6 6MT 2004 cavalier
    Charlotte/Roanoke
    18zs here was a nice improvement over stock in my a6. pedal is firmer no doubt but its easier to modulate. I don't regret it and wouldn't go back
    Jun 26 2013
    I have 18Z's, excessive pedal travel lasted a few hours . Re bled system , Bedded pads and everything felt great
    Apr 01 2011
    B5 on jack stands
    charlotte
    ^^this
    Kinda ran into the same thing with Porsche calipers. Drove it a bit and asll was good
    powered by
    Hot Boi parts
    Feb 09 2013
    WNY
    So far seems like 18Z has better feel and less issues than 17Z.
    Aug 25 2013
    I have 18z, I'd say the pedal feels way better than stock, very easy to modulate
    Nov 16 2010
    WetSide, WA
    17z and 18z feel the same. They both use the same pad and pad choice is a change people can actually feel.
    Take these little demons of deceleration for exampe:
    If you dont respect the pedal, these dirty beeatches will launch the the headlights clean out of the grill.
    They also come with the auto-black option for that sweet murdered out wheel look. I recommend replacing fr/rrr at the same time to maintain balance.
    Not brake balance we are worried about here, but you just aint pimpin properly when the front wheels are black and the rears are silver.
    Jul 04 2012
    Woodbridge, VA
    ^^^ ding ding ding..... We have a winner.
    Now close thing thread already lol
    Feb 09 2013
    WNY
    17Z and 18Z pads are slightly different. 18Z pads are taller than 17Z. But yes, pads make a big difference. I just wanted to get a few opinions from people.
