Results 1 to 8 of 8
    Junior Member Two Rings
    Jul 28 2014
    quebec
    Angry 1.8t engine build question
    hi , i now building a 1.8t with je piston and eagle rods. i run a stock aeb head! my question is ! can i time the engine the same as stock or i need to time the engine differently ( timing belt ) ?
    Dec 28 2015
    Wake Forest, NC
    There should be no change in timing if you have not changed the compression ratio. CR changes will need to be dealt with in software (tuning).
    Sent from my XT1585 using Tapatalk
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Is this for serious? Dude could change compression ratio to 20:1 and he would use the same tbelt.
    Quote Originally Posted by CaptainJohn View Post
    Tbelt stays with the bottom end, so use the stock one.
    Do not forget, you want to run an 06a cam gear too. Don't use the AEB one. If you are using the AEB cams you will also want to switch the cam trigger wheel under cam sensor to the AMB one. You will notice the AEB one only has one notch in it, while vvt cars have a couple.
    Besides that, remember to stick with 06a head bolts, the 058 ones are 11mm. You need 10mm bolts
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Dec 28 2015
    Wake Forest, NC
    Quote Originally Posted by redline380 View Post
    The initial question was somewhat ambiguous. The belt would be the same, however, ignition timing would change dramatically, which is why I referenced software.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Understood. I took his question to regard mechanical timing, not spark timing. But yes, if he is going to change comp ratio, tuning would be advised.
    2000 S4- Working?
    Jul 28 2014
    quebec
    thanks every one , i change the cam gear and the trigger wheel . i will put my head tomorrow and i will stay win the poem timing
    Aug 26 2005
    Quote Originally Posted by nicolas543 View Post
    There are no alternative cam timing settings. Even if an adjustable cam timing belt sprocket is used, the only reason for using it is to be able to adjust the cam timing to the exact OE stock cam timing with relation to the crankshaft, using a degree wheel on the crankshaft. This can eliminate any random variation of the base cam timing due to tolerance stack up.
    Vorsprung durch Technik
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    That's not how IE uses it.
    http://www.performancebyie.com/blog/...able-cam-gear/
    2000 S4- Working?
