Results 1 to 18 of 18
    Junior Member Two Rings Warhorse99's Avatar
    Mar 01 2015
    2007 RS4
    Colorado
    Any Advice/experience with Short Shifter on B7 RS4?
    Am thinking of installing a short shifter on my RS4. Anyone have advice on whether it's worth it and if so, which kit?
    Thanks,
    Michael
    Senior Member Three Rings Gareth_oau's Avatar
    Mar 13 2011
    Perth Australia
    absolutely worth it $275. from jhm, plus an hour of labor.
    Of all the mods you can do, this one is the best bang for buck, and you will use it 100s of time every day
    Removes all the "sloppiness" in the OEM change and turns it into a bolt action change.
    here's a vid of how good the (stage one) change is.
    APR ECU Upgrade, JHM quickshifter, Milltek catback exhaust, Milltek 100 cell downpipes, JHM lightweight Clutch, Argon CF Splitters, KW V3 Coilovers.
    Veteran Member Three Rings dturn37's Avatar
    Jun 06 2014
    Chicago IL
    I'm in the same boat as you Warhorse99. Been thinking about getting an JHM short shifter for about a year now. Got a little nervous after reading people having problems getting it adjusted properly. How's everyone enjoying their short shifters from JHM?
    CAPRISTO EXHAUST, KW V3 COILOVERS, EURO HEADLIGHTS, R8 ALCANTARA STEERING WHEEL.
    Sep 27 2011
    Tomatoes
    Eastern PA
    JHM kit is top notch. I wouldn't bother with anything else.
    Suzuka Gray 2015 S3 Thread
    Misano Red 2003 RS6 Thread
    IG: @Flying_Tomatoes
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    Get the JHM. Don't be afraid of the adjustment. Sure it may be a bit finicky, but once it's done it's not like you will have to constantly adjust it.
    Veteran Member Four Rings MattboyR32's Avatar
    Nov 28 2006
    Orange County, CA, USA
    I have the JHM. its a little finnicky, but be patient with it.
    my tips (some of them plagiarised from the JHM site/video)
    - remove/move out of the way the AC controls (need to remove radio first). just gives you more space to play around and get it right.
    - adjust the lower linkage first until you can get 1st and reverse easily
    - once you have 1st/reverse sorted then the upper linkage will get you the rest of the gearbox
    It makes the 1st/2nd transition so much better than OEM, then after that get your diff mount and transmission mount and shifting is much better than when it came from the factory and you look like less of a nonce as you drive away :)
    B7 RS4 6MT Daytona Grey
    JHM 2.75" catback non-res, piggie pipes, 034 transmission, engine mounts, strut mounts & end links, Apikol diff mount, Hotchkis adjustable rsb, Escort 9500i (HW), JHM lightweight rotors, JHM intake manifold spacers, BC Racing coilovers,
    RIP: B7 S4 DTM 6MT Dolphin Grey
    JHM Tune, Corsa Catback, Piggie Pipes, Bilstein PSS9, RS4 Reps, Blackvue Car Blackbox (HW), Escort 9500i (HW)
    Mar 13 2011
    Perth Australia
    I had a mechanic install mine. cost me 1 hour's labor - its been in for 5 years now, and not a single problem with it
    Veteran Member Four Rings Mistro's Avatar
    Jun 19 2011
    Definitely worth it. A bit finicky to adjust but once you understand the general jist you'll have it dialed in in no time.
    Dec 05 2006
    So. Cal.
    I love mine. A flawless unit, once adjusted properly.
    you have to be mindful when installing it. Keeping in mind what every adjustment does to it. Once you understand, it's as easy as pie.
    Veteran Member Three Rings Reggie's Avatar
    Feb 27 2005
    2014 SQ5 & 2015 RS5
    Fort Collins Coloardo
    I put one in mine and loved it. PIA to adjust but as said above worth it
    Oct 11 2007
    Suburbia
    Do you guys have to constantly or even occasionally re-adjust the shifter? I'm interested to get on board, but don't want the hassles of tweaking it even sometimes. I want to set and forget.
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Custom CAI~Bilstein PSS9s~Girodiscs~JHM shifter~
    Veteran Member Four Rings denis silva's Avatar
    Apr 14 2009
    2007 passat,subaru outback
    san mateo
    I have the trio from JHM for a long time, and love it
    Sent from my iPhone using Tapatalklk
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by WinterRunner View Post
    Ive had the same one that I have used on 3 different cars for close to 30K miles, after the initial adjustment I have never touched it until it was removed when I sold the car.
    Aug 07 2007
    B7 ABT Avant
    After the initial install I've never touched it again.
    Senior Member Three Rings bigoltater's Avatar
    Jan 27 2015
    2013 Q7 S Line / Prestige, 2005.5 S4
    Bend,OR
    I'm thinking about ordering one, is there a dyi thread for install?
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Established Member Two Rings Ravage's Avatar
    Aug 01 2014
    Quote Originally Posted by bigoltater View Post
    I did the install last week. Videos on youtube for the diy.
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    JHM, full stop. I don't mind the stock shifter throw, but if you want to go aftermarket, do nothing other than JHM. A little tricky to get the alignment right, but its so good once installed.
    Jun 06 2014
    Chicago IL
    Ok I placed an order for a JHM short shifter. If you guys had to do it again, what advise would you give a new installer. I've watched the JHM video a few times but is there any tricks that would help me dial this in quicker. Knowing me, I'll be "dialing it in" for the next 3 months haha
