Results 1 to 14 of 14
    Veteran Member Three Rings skhan91's Avatar
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    anyone running 20x11 all around?
    anyone running 20x11 all around? if so, what tires?
    tried looking through but couldnt find specific examples.
    thanks in advance!
    Oct 31 2005
    Ashburn
    My opinion, with 20X11 you will have a hard time with fitment in the front and will need rubber bands as tires. Also might be a issue with inner wheel well clearance.
    I'd say a 255/30 on a 20X11.
    - Instagram: @Sinister_rs5-
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    yea i think it will be difficult but i really want these wheels:
    http://www.audizine.com/forum/showth...ave-20x11-et28
    the most i have seen is someone running 20x10 in the front and 20x11 in the back with these exact wheels
    plus the tires on these are 295s lol
    Oct 31 2005
    Ashburn
    Quote Originally Posted by skhan91 View Post
    My buddy has a pair of Rohanna wheels on his RS4 and he already has 2 bent wheels and the RS4 isn't even his daily. I think theses wheels were on the Black RS4 Avant from like Poland or something right? I liked these when I first saw them but later passed.
    You could probably make it work but the added money to make it work can be spent on a nicer set of wheels in my opinion.
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    I have 10.5" wide wheels and could not fit anything more without some extreme camber.
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    yea looking like i will pass on these wheels. its a shame because i really like the RC10 design.
    thanks guys!
    Nov 03 2010
    Cupertino, CA
    Can you get the barrel changed?
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by BenSti View Post
    sorry what do you mean by the Barrel changed?
    Jun 18 2009
    Phoenix, AZ
    3 piece wheels sometimes mean you can swap out things like the center section or "the barrel" which is the 11" wide part, in this case, for something smaller (or larger).
    2017 Camaro SS 1LE
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by FWP! View Post
    ahhh i see. interesting. dont the the RC10 are threepeice. even then, the tires with these wheels are way too big at 295 lol.
    probably better to look for 20x10 or 19x10 instead :S
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    What size tire are you running with the 10.5's? And offset? I'm planning on rolling the fenders and getting upper control arms to get a little bit more front neg camber.
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Sep 27 2011
    Tomatoes
    Eastern PA
    I ran a 19x10.5 all round with some camber. I can't see a 20x11 fitting up front with out lots of rubbing.
    Suzuka Gray 2015 S3 Thread
    Misano Red 2003 RS6 Thread
    IG: @Flying_Tomatoes
    Nov 03 2010
    Cupertino, CA
    Quote Originally Posted by AvusPdx View Post
    18x10.5 +25 275/35 NT01
    Feb 23 2010
    Nebraska
    20x10.5's on my car. rubs a bit over bumps and in turns/curves taken at speed. But 90% of the time it's fine.
    ~ Matt J
    IG: @rsrtsvt
    '08 RS4 -- Suzuka
    991.2 GT3 -- Chalk (SOLD)
    '15 R8 V10 Plus (SOLD)
    '07 PB Audi RS4 (SOLD)
