Results 1 to 36 of 36
    Established Member Two Rings Spenceratc7's Avatar
    Jan 28 2016
    Orlando
    AWE Track Exhaust- Sound Actuator
    I just put on the AWE Track exhaust on my 2014 S4. I have seen a lot of threads and directions saying to turn off the sound actuator.
    Most of the diagrams have 2013 models or older and was wondering if anyone knew which fuse I needed to pull to turn it off. Audi has been a royal pain to
    get them to give me any type of user manual (bought the car used and didn't have one).
    On a side note the reason I would like to do this is to reduce some of the cabin noise. I love the deep sound but I need to dim it or my Fiance will make me trade the car in lol.
    I have seen a few threads also on sound deadening material but they are also on older models. Anyone tried to reduce in cabin exhaust noise on their 14 S4s?
    Mar 21 2015
    You can adjust it in the mmi. You can lower it but not turn it off. I forget the fuse right now but pulling it will throw some soft codes but nothing harmful. You can turn it completely off with vcds, which I did.
    Jan 28 2016
    Orlando
    Ok thanks, I was not too worried about throwing codes at the moment.
    did it make a reasonable difference for you?
    I'm hoping someone has found a good solution to get the cabin noise reduced. If i don't find a way to get my fiance in the car I may have to trade back!!! and that would break my heart lol
    Mar 21 2015
    You definitely notice turning it off but you have the louder of the two exhausts from AWE. Shoulda went touring model.
    Mar 21 2015
    Type your vin in here and you can view your maual online to find the fuse.
    http://ownersmanual.audiusa.com
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    ^ This. The touring model is the quieter one, still sounds good outside lol.
    Good luck!
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Veteran Member Three Rings carlosvjr92's Avatar
    Nov 25 2015
    Miami, FL
    Trade the fiancé, keep the exhaust. Problem solved :P
    In all seriousness - if you are the first buyer/owner of this AWE system you should be able to purchase the mufflers from the touring separately from them. That plus lowering the sound actuator should help a lot
    2018 RS3 (Cumulus Blue) - APR Stage 2 || APR Intake || APR Downpipe
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Driver side fuse box, left most column, 5th slot down, it's a yellow 5amp fuse. It does make a noticeable difference, just pull it.
    AWE Touring with resonated downpipes and my fuse is sitting in my ash tray.
    Jan 28 2016
    Orlando
    Have any of you guys heard the touring and the Track (with stock downpipes)? Is there a large difference? Do you think anyone would be willing to trade their touring exhaust?
    I actually got mine second hand
    - - - Updated - - -
    Also thank you for the fuse direction guys, I will be pulling that bad boy out shortly.
    Mar 21 2015
    I have not heard the track but with two mufflers added there is probably a pretty noticeable difference. Sound clips all over the place. AWE has some on their site I believe.
    Jan 28 2016
    Orlando
    Man I thought I did enough homework. I have to say (even though I do love it) I was not prepared for the difference in sound. None of the videos can even come close to capturing the sound these bad boys make in person.
    Deactivated Three Rings
    Aug 24 2015
    How do you make the Sound Actuator Louder? Serious question.
    Sent from my iPad using Tap,Tap,Tapatalk
    Mar 21 2015
    Quote Originally Posted by S4NJ View Post
    Post 2
    Aug 24 2015
    Post 2
    I mean can it be swapped out for a slightly larger unit?
    Jan 28 2016
    Orlando
    I have done quite a bit of reading for this, and there is not a way to make the actual Sound Actuator louder. In your MMI settings I believe there is an Exhaust level that you can select that will help change the volume. But the levels you have in there are what you are limited to
    Mar 21 2015
    Never heard of it
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    Found this for you:
    https://www.youtube.com/watch?v=1RZwwYXNzgM
    http://www.carguygarage.com/soundracer.html
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    Aug 24 2015
    I just flipped thru 77 online pages of the manual and there is no mention on how to change the sound of the actuator anywhere in the MMI. and it's too cold to go outside now to check it out lol
    Aug 24 2015
    The problem with this solution is that it hijacks your radio :( but it does sound nice!
    Jul 20 2015
    Connecticut
    Good point. If these things weren't selling out as fast as they can produce them, I'd think about picking one up for the laughs. I'm getting way too much amusement from the thought of setting it up in my wife's car.
    Mar 21 2015
    I wouldn't call that a solution, besides it sounds horrible.
    Dec 07 2014
    Mn
    Just turn it off all together. I'm on stock exhaust and it's so much better not having that fake shit pumped in.
    Sent from my LG-H901 using Tapatalk
    2014 S4 DSG///Unitronic Stage 2+.
    Mar 21 2015
    Quote Originally Posted by brianc21 View Post
    I agree 100%
    Mar 21 2015
    Quote Originally Posted by Spenceratc7 View Post
    You might have better luck trying to find someone that bought a track exhaust originally and see if they can order the mufflers for you. That seems easier then trading. Id do it for ya but I can't.
    Senior Member Three Rings migo1980's Avatar
    Sep 05 2007
    Raleigh, NC
    Ive muted mine with the vagcom...i suppose you could make it louder here too.
    "To mute the Soundaktor (as an alternative to pulling the fuse):
    A9 Structure Borne Sound (in my car, this was in the second Installed tab, not the first one that's shown by default)
    Adaptation 10
    At Channel drop down choose "Volume of structure borne noise actuator" (only choice)
    Enter a value in the proper box (0% = mute )"
    Jan 28 2016
    Orlando
    Thanks guys, I actually ended up pulling the fuse last night and the over all sound quality is much better. The Actuator was creating what I can best describe as an echo in the cabin that really made everything worse. Without it the exhaust sound is great!
    Now I'm thinking I may throw some dampeners in the trunk lining to try and dim it in cabin. That seems to be the quickest fix bc no one is biting on a trade for touring. Hopefully that will please the fiance and will be a win win!
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    This is why I dont have a fiance... LOL
    Mar 21 2015
    Tons of guys that bought the Track originally. See if someone will hook you up if you send them the money.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    did you get a code when you pulled fuse 5?
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    DEATH TO THE SOUND ACTUATOR!!!
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Oct 13 2009
    MN
    Quote Originally Posted by migo1980 View Post
    Adaptation 10
    Thanks for the posting this. Was having a heck of a time trying to find instructions to do this through vagcom, which I think is a better option VS pulling a fuse.
    Mar 21 2015
    Quote Originally Posted by CrownSeven View Post
    Its all right here in this wonderful sticky
    http://www.audizine.com/forum/showth...-complete-list
    Oct 13 2009
    MN
    Well now....
    Jan 28 2016
    Orlando
    Nope believe it or not I did not get any type of code pulling this fuse, however before I knew which one I actually needed to pull I did the wrong one and it did send a code.
    I put it back in though, hard reset the car and everything is not fine. Fuse #5 is out and the cabin is much better
    Senior Member Two Rings jayferzahir's Avatar
    Feb 05 2015
    Audi S4 and Audi R8 Spyder
    Westlake Village, California
    bringing this back
    is it a noticeable difference in drone with the actuator pulled? I tried pulling the fuse it says in the booklet but it is giving me a parking brake error..
    2016 B8.5 DD
    RS Grille| CTS Intake| ChipWerkes Pro| AWE Track| 10% Tint| interior LED upgrade|
    2014 Audi R8 V8 Spyder SOLD
    2013 Mercedes C63 SOLD
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    Quote Originally Posted by jayferzahir View Post
    bringing this back
    Yes it is helpful to remove the fuse. you must've pulled the wrong fuse. It is in the fuse box located on the side of the drivers side dash with the door open. Left most fuse bank, 5th fuse down from the top. But don't just count the fuses and pull the 5th. there may be empty fuse banks in between other fuses (like on my car) because your car doesn't have certain features.
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
