Results 1 to 6 of 6
    Senior Member Three Rings Jey4's Avatar
    Apr 02 2013
    West Haverstraw/NY
    Oil cap leak with catch can setup
    So I needed to replace my pcv and decided to go with a catch can setup. It's been running great for about a month now and this morning I noticed a rough idle. Seen smoke coming from the hood along with the smell of oil so popped the hood and oil is spitting out the cap. I know this is a symptom of a bad pvc but with a catch can setup what could be the problem now?
    -Jey
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    Wow. Can you post a pic of how you have the catch can installed as well? And which catch can is it?
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Frozen liquid in the hoses...
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by james12lucy View Post
    Or the can itself is full and frozen. Something is causing massive positive pressure in your crankcase and the oil cap was the easiest way for it to get out.
    -Adam
    Jun 17 2013
    jersey city nj
    x2
    Apr 02 2013
    West Haverstraw/NY
    It's an 034 Billet with the oil return line. Something must of froze up inside. When I drove the car home from work it ran fine. It's been well below freezing for the past few days here in NY.
    Sent from my Nexus 6 using Tapatalk
    -Jey
