Results 1 to 40 of 55
Thread: Options
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Options
    Morning gents,
    I've spent a lot of time and money on my Avant only to lose it to a simple bullshit accident that could've been avoided. I'm looking for a "decent" replacement to my Avant but sort of stuck at a crossroad as to what I want for a daily. I've literally gone across the spectrum in terms of my choices, from a Pontiac G8 GT/GXP to an F80 M3 and even "downgrading" to an F31 328i xDrive Sportswagon. As of this moment, I'm sorta just lingering around, bouncing back and forth between the F31 and B8.5 AR.
    Question is for the ones that transitioned from the 4.2 V8 to anything less than a 6cylinder...how did you all like it? Does it leaving you wanting more?
    Any suggestions you all have that covers my price range of >$30K used?
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    I can't really answer your question, but as someone likely in the same boat within the next year or two...
    Do you have kids? Need/want wagon | sedan | coupe?
    gl with search
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by badger. View Post
    gl with search
    9mo old twins plus 6yr old; this would be my daily so they wouldn't really ride in it unless I was off that day and needed to transport them somewhere but wifey has manage to transport all of them in her silly little Prius soooo there's that feat.
    My want for a wagon is purely for entertainment but is NOT a necessity. As I said earlier, I've gone across the spectrum for what I would like and the F80 M3 really fancies me but just too damn expensive, as does the Giulia
    2015 B8 SQ5
    Click Here
    Past
    Jan 10 2007
    VA
    In that case I'd avoid the 4cyl cars. Don't get me wrong, the 2.0T motors in the F31/B8.5 are great DDs. Tuned they're nipping on the V8 S4s heels performance wise. They feel completely different though. All 4cyls have certain Noise, Vibration, and Harshness that is inescapable. The 2.0Ts are all low to mid-range power and lack top end. So even though they're quick, they don't feel or sound anywhere near as good as a 6 or 8. As an enthusiast, especially one use to a 6 or 8, you'll always dislike those qualities. If a wagon isn't a must get an S4 or 335i. They may give up a few cubic feet or cargo space, but its much nicer having a larger, smoother, more powerful motor.
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    I just picked up a B8.5 Allroad. It's got plenty up go-power, and if you get the ADS option (or VAG-hack it) the throttle and transmission respond a lot more aggressively. Driving that now as my daily, and honestly the only thing I'm missing from the S is the sound and rowing through gears.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Off topic but sorry to hear about your car man :(
    Current: 08 R8 6MT, 14 Cayenne GTS, 98 Saleen XP8
    Past: B7 RS4, '12 Audi TTRS BT Build | 2006 Audi S4 HPDE Build | 2006 Audi A4
    Visit my blog: NicksCarBlog.com
    Established Member Two Rings seblove's Avatar
    Feb 28 2013
    los angeles, ca
    I went from a bolt-on B7 S4 to an 8P A3 for a short time. I put a turbo-back on it and a tune and it was definitely quick, but left me wanting more sound and a more solid feel that I got with the much heavier S4. The A3 might be an exceptional case because it's essentially a glorified vw but I'd wager you'll be left wanting more if you go toward a 4-cyl audi. Also, your spectrum is extremely wide if you're considering a new m3!! If I were in your position, I'd definitely go for a medium-low mileage B8 S4 manual. You get crazy gains for the $$ put in on what seems to be a reliable engine, the car looks fantastic and sounds better (imo) than the new m3/m4, and you get to keep the solid feel that you're used to from the B7. Also, I'm very sorry to hear about your car, 'tis the stuff of nightmares :(..
    2008 RS4 Satin Pearl wrap - JHM stg 1+ blower - full JHM exhaust, resonated & catless - JHM LWFW & 3R clutch - PSS9s + 034 control arms & sways - JHM short shift + linkage - Apikol Rear Diff Mount - Stern Motor Mounts - 034 Snub Mount - 034 Trans Mount - JHM IM spacers
    Veteran Member Three Rings 1MoreSilverA4's Avatar
    Sep 15 2004
    '04 S4 Avant - '03 A4 Avant 3.0 - ‘03+’04 Allroads
    VA
    If I was to ever replace the s4 avant, it'd be for a new allroad. Sorry for your loss
    Part out?
    Senior Member Three Rings cmd4's Avatar
    Jan 09 2010
    asheville
    Honestly i had a love for avants as well and recently sold my beloved 57k b6 6spd avant….I always lusted after a rs4 and just picked one up, love it even more than the wagon! with your budget i'd strongly recommend checking out a rs4…it's everything you wanted your s4 to be..and then some! Coarse i also contemplated finding a 4.2 v8 allroad and attempting a 6spd swapthen I remembered i had kids close to same age and that wasn't a realistic project to bite off
    RS4 mugello blue,Ti-Curing the itch
    04-Cobalt Allroad 78k 6mt- Car seat duty
    b6 s4 avant blk/blk-57k 6mt Gone
    DD -03 7.3 pwrstrk 6spd 200k and counting
    85 fj 60 lt1 and nv4500..Gone
    96-993 C4S…Gone
    78-fj40-smb350…alum tub,aussie 4spd,orion t case ,detroit locked
    97-40th fj80 on 33's and arb front
    Senior Member Two Rings lathdogg's Avatar
    Jun 01 2012
    Laramie, WY
    I went from a 2007 S4 to a 2015 GTI S about a year ago and I have very few regrets. I miss AWD and V8 but don't miss 14 mpg. I live at 7200 feet above sea level so I never got to fully appreciate the power of the N/A 4.2. I'm very impressed with all the GTI has to offer, it's a great DD with plenty of utility. The backseat is a tad bigger and more comfortable along with the benefits of a hatch. I love DSG and I love the 2.0 TSI, my only complaint is you can't get a GTI with 4motion. It's a great option for someone looking for better gas mileage without having to sacrifice much in overall performance.
    2015 GTI S
    Dec 02 2007
    DC/MD/(VA)
    Options
    Quote Originally Posted by b6onboost View Post
    Like this answer the best, thanks for the honesty. I'm not a fan of the B8/8.5 S4s, something about them irks me; can't place my finger on it but I feel like I'm removed from the car, as if I'm just sitting there numb, holding a steering wheel.
    Quote Originally Posted by earhythmic View Post
    I should probably browse the Avant section for your progress thread but what have you done with your AR, performance wise? Comparable to your old S (can't remember what mods you did to it)?
    Quote Originally Posted by nnnick View Post
    Thanks Nick...still salty about it being gone but what can I do right?
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    get an allroad, stage 2 3.0 T swap it :) happy camper !
    i dont daily drive my s4 anymore. i have x5 and whenever i get a chance to take out the S its like daaaaaaamn im never gonna sell that car ! :) so heres your answer. id look for rs4 or m3 :)
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Dec 02 2007
    DC/MD/(VA)
    Options
    Quote Originally Posted by Lucca M View Post
    Such a silly notion by Audi not to have the AR with a 3.0T as the base engine.
    Oh and I have considered a 4dr e90 M3
    2015 B8 SQ5
    Click Here
    Past
    Jan 17 2014
    New Jersey
    Well they do have rs4 avant in europe so why bother with allroad
    Insta: luccamentone
    Veteran Member Three Rings [a]bek.'s Avatar
    Mar 14 2013
    This is without reading any posts. So, I would honestly look for some nice G8 GXP, not the GT because the GXP has the 6.3? corvette engine. And let me tell you, on my way back from Virginia to New Jersey, I raced one he said he had full straight pipe and tune and he ate me alive. I only have about 307 dynoed awhp for my S4. But that GXP is not a bad looking car and it's fast as shiii
    Active Member Two Rings remuspwr's Avatar
    Sep 21 2010
    RX 330
    What about a Panamera? You can get it in all flavors. 6 or 8, NA or turbo and RWD or AWD. It's got the space like an avant... But certainly not the same price as a B6/7.
    Dec 02 2014
    Dallas, Tx
    If you like the G8, look into the Chevy SS, much much much better looking inside and out. Same platform.
    Nov 12 2015
    Oregon
    My build log
    Established Member Two Rings cobraBLACK's Avatar
    Dec 06 2010
    UK
    Surprised you're not into a B7 RS4. Is it just because they don't do the Avants over there?
    Audi S4 Avant (B6, 2004) in Goodwood Green. V8, motherhubbards!!
    Jan 14 2009
    Audi's
    If you don't need a wagon RS4 seems to be the way to go. If they came in Nogaro I would of jumped ship years ago
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 04 2014
    2009 Gray A3
    California
    A good friend of mine who has owned both 2010 + 335i and A4 3.0 went with a new WRX
    He liked the power as well as the good mgp
    Jan 17 2014
    New Jersey
    Quote Originally Posted by Mr. Corey View Post
    Well you can always make it noggy
    Insta: luccamentone
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    I'll throw in another vote for a RS4
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Dec 02 2007
    DC/MD/(VA)
    4.4L V8TT X5 xDrive 50i
    2015 B8 SQ5
    Click Here
    Past
    Senior Member Two Rings BluntAaronR's Avatar
    Dec 04 2014
    '08 Audi S4 Avant '14 SQ5
    Park City, UT
    Quote Originally Posted by VinnysS4 View Post
    I second this notion.
    After exclusively driving our '14 SQ5 for 3 weeks, I drove our B7 S4 Avant today. Although I still love the S4, the SQ5 has better throttle response, is more comfortable, and every day blows my mind with how well it handles for being an SUV.
    Decisions decisions....
    Jan 17 2014
    New Jersey
    i like where this is going :)
    Insta: luccamentone
    Dec 02 2007
    DC/MD/(VA)
    serious...i'm looking at a few xDrive50i's; 22-26K @65-86K miles.
    the one I'm SERIOUSLY interested in has the M-Package on it sooooo yaaaa
    2015 B8 SQ5
    Click Here
    Past
    Jan 17 2014
    New Jersey
    My friend has one, white with beige interior and msport. Love it! And this car with tune and exhaust is a monster.
    Insta: luccamentone
    Dec 02 2007
    DC/MD/(VA)
    Do me a favor, ask him how it handles in the snow and what type of "issues" should I be looking for.
    2015 B8 SQ5
    Click Here
    Past
    Jan 17 2014
    New Jersey
    He has this car for over a year now, no issuess at all. He runs 20s in the summer and put 18s with winter tires for winter and ive seen this car going strong on few inches of snow. But ill ask him more details.
    Insta: luccamentone
    Dec 02 2007
    DC/MD/(VA)
    Thanks man...I might end up committing to this X5 business. PM me when you get the deets; thanks again.
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    Friends OEM RS4 widebody S4 Avant is still for sale
    "Brake last, finish first."
    Jan 17 2014
    New Jersey
    Quote Originally Posted by NYC_Legacy View Post
    No! Prezzi is not selling it :p i won't let him. Haha
    Insta: luccamentone
    Dec 07 2009
    East Coast
    ^That would be a good starting point for an potentially epic project.
    Since you're considering M3 sedan, I'm going to throw a wild card e39 M5???
    Forget the B8, keep the V8!
    Dec 02 2007
    DC/MD/(VA)
    Options
    Quote Originally Posted by Mr.Wrong View Post
    Looked into it and well considering I have a better option WITH AWD in the X5, guess what I'm leaning towards .
    I submitted an inquiry with the owner today to see where his price point lies. I also put in a quote to Navy Federal to see what my monthly payments would be; also submitted a quote for insurance via USAA.
    Next thing is to see how "reliable" the N63 4.4i is ....I've been known to take on things that go boom unexpectedly
    2015 B8 SQ5
    Click Here
    Past
    Dec 07 2009
    East Coast
    Those V8s haul quite well actually. Comfortable inside and got room to spare for cargo. I'd suggest getting one with extra row of seats, especially for those with kids, comes in real handy.
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    SQ5 or allroad. I still stand firm on kicking you in the nuts if you buy a fucking BMW
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by FastEddie View Post
    AR has an underpowered 2.0L turbo4.
    SQ5 has subtle 3.0L S/C V6.
    X5 xDrive50i has a ticking time bomb 4.4L V8TT.
    Ed, you know me well enough to understand which one has JUST captured my heart.
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    u have kids so u need the bigger car , buy q7 with v8 and u have everything 4 rings on grill, lot of space and v8 sound
    Jan 17 2014
    New Jersey
    If you go with x5 im sure you will like it but remember it a fucking heavy car so even with v8 its not gonna be super quick, but it is pretty damn quick for an suv. I enjoy mine and its perfect daily.
    Insta: luccamentone
