Results 1 to 4 of 4
    Established Member Two Rings p310b's Avatar
    Jan 15 2016
    Indonesia
    Hpfp hard line question
    Hi, does anyone knows or has picture on hpfp fuel line from the tank. The one running on the top of the manifold and connected to rubber hose.
    I want to know if it has any restrictor at all.
    The part number is 06D127509N and its the newer non banjo fitting.
    Heres pictures waht I'm talking about.
    thats the line
    this is the one that I want to know whether it has restrictor. The banjo type line has a restrictor here.
    I broke my hard line on the banjo fitting and have the barb union that screwed into hpfp which has restrictor. I'm buying the hard line conversion and it arriving in 4weeks and for now planning to hack the banjo end and use rubber hose.
    But, since the new fitting has a restrictor , i want to know if the newer line has restrictor to avoid running two restrictors.
    Thanks!!!
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    Just buy the right line, I got a used one on eBay for $30.
    Jan 15 2016
    Indonesia
    The problem is Im in Indonesia and Its going to take a month to order it from abroad. I will still buy the correct line. But for fast solustion I just want to know.
    If the new line has no restrictor, I will drill the line to remove the restrictor for now.
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    So help if anyone can. The fitting that goes into the PRV seems to be a 6an or 6mm. The ball rounded fitting doesn't seem like an easy piece to replicate or find in acklands grainger catalogue. Any suggestions as to what is used when swapping the fuel lines out for 3/8" rubber? The T I believe was causing me fuel cuts. So time to change it out.
