Results 1 to 4 of 4
    Jan 05 2015
    London
    Fuel trims and temperature question
    Quick question for those that log this kind of data on a 2.0T
    - How much do your long term fuel trims change with temperature?
    I understand that lower temps means higher air density so should push values a bit more positive as the O2 sensor adjusts for the mixture, but I am quite interested in actual (Vag COM block 32 or just with a bluetooth device) values.
    I find that my idle/add trim doesn't move much, but my mult/part/throttle value moves by around 4% between say an outside temp of 0 degrees and an outside temp 20 degrees Celsius. Wondering what other people get?
    Jan 05 2015
    London
    Anyone got any data to share? If not, maybe a few of you could note the fuel trims now and then note it when the temp changes and let me know.
    Cheers
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    They shouldn't change a lot with temp but should change with driving style and fuel quality
    Jan 05 2015
    London
    Mine swings quite a bit - even with same tank of fuel let alone the same make (we've had one day to another swings of 12-13 degrees) and this makes up to a 2% difference in fuel trim... Wonder what could cause that?
