Originally Posted by
LightningLou
So I already have the jhm ss, but looking to add the solid linkage and crossrod now that I have noticed some extra slop and inconsistent shifting at higher rpm's. Who has installed this combo with the trans still mounted? I'm sure it's going to be a royal pain in the butt, but is it doable? Any pointers before tackling this would help a lot. Thanks!
I didn't install the JHM, but I did bolt down the OEM linkage and crossrod with the trans still in the car. I had axles and shielding all out so it made it a lot easier. people say that 8mm OE hex bolt that holds the crossrod in can't be accessed in the car, but, oh it can. I fashioned something together that worked like a charm: 8MM hex bit inside of an 8MM closed ratchet wrench works perfectly. it was definitely awkward though. like giving a small bear a hug for an hour. to answer your question, it would be doable, but it's definitely not something I'd look forward to doing.
