Results 1 to 17 of 17
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 23 2004
    You gotta see how the dealer deliverd this BMW 335 X Drive - swirl o rama!
    Paint correction - also known as swirl mark removal or machine polishing, paint correction is the reduction or removal of marks in the top layer of paint to produce a more refined finish.
    Paint correction will involve machine polishing and various grades of cleanser, polish, or compound. The majority of work is usually done with orbital or rotary machine polishers to get the best level of correction.
    Great paint correction requires a high level of skill and concentration, but done properly, paint correction can transform the look of a car by dealing all the issues discussed above.
    Reasons to seek out paint correction services:
    - Road grime, grit, tar
    - Bird crap, dead bugs, and tree sap
    - Water spots
    - Improper wash techniques and products used
    - People brushing against the car with their clothing or bags
    - Holograms and swirls caused by lack of proper training and techniques
    - Automated car washes
    All of the above can leave the paint of a car looking imperfect - dull, faded, and covered in various level of scratches (from light to heavy), swirls, and marring.
    For most vehicles, paint correction really can make a substantial difference and will completely remove or significantly reduce most marks. Once the paint correction is done the results will display amazing gloss, depth of color, and slickness.
    The customer of this BMW 335 had a budget in mind so here is what we were able to do for him.
    We will remove
    - 50 - 70% of deeper swirl marks.
    - Remove etching from water spots and bird etchings.
    - Remove and or reduce lighter scratches and marring
    - Remove surface contamination
    - Restore faded and dull paint
    - Polish and bring back gloss and depth of paint
    Will not remove the all swirls, or deep scratches. We will not be fixing rock chips at this level either.
    Products used on this job:
    Nanolex Prewash Concentrate
    Nanolex Wheel Cleaner and Iron Remover
    Nanoskin Autoscrub Sponge
    Nanolex Glass Cleaner
    Meguiar's M205
    Sonax Polymer Net Shield
    Nanolex Tire and Trim Restorer
    Tools used:
    Metro Air Force Blaster 8 hp
    Rupes LHR15 MKII
    Rupes LHR75E
    Griot's 6 inch random orbital polisher
    Meguiar's Microfiber Finishing Pad
    Uber All Purpose MF Towels
    Uber Classic MF Towels
    Scangrip Multimatch Light
    Before shots will give you a good idea of how bad this car was taken care of by it's former owner.
    Wash/Decon/Prep
    Decon using Nanolex Wheel Cleaner and Iron Remover
    Wheels also cleaned with Nanolex Wheel Cleaner and Iron Remover
    Foam bath - using Nanolex PreCleaner Wash
    Clay using the Nanoskin Sponge on paint and glass
    Rinse
    Metro Blaster 8 hp used to dry the paint and wheels
    Imperfections
    Feb 23 2004
    Severe flaws in paint
    50/50 shot of the piano black trim on the BMW. Light scratches are quite common on trim like this, faded and dull, we fixed it using Menzerna SF4500 with an Uber Green Pad
    50/50 shot of the rear quarter
    50/50 shots on the paint
    Rupes LHR15 MKII working some magic
    Rupes LHR75E on the tight areas
    The Griot's 6 inch comes out to play.
    Meguiar's Microfiber Finishing Pads lots of them.
    Paint improved
    Final shots
    If you have any questions, please don't hesitate to drop me an email.
    [email protected]
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    You use nanoskin sponge before any other mitt or wool?
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Feb 23 2004
    we wash the car first with a mitt then rinse and follow up with the nanoskin.
    Jun 10 2008
    Spiders
    Chicago And NJ
    Got it so you respray wth foam gun as the lubricant?
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    How much does something like that cost?
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Feb 23 2004
    Quote Originally Posted by aaronz View Post
    yes sir.
    - - - Updated - - -
    Quote Originally Posted by DannyDeez View Post
    pm me or email me.
    Feb 17 2013
    Q7 . A3 3.2 Quattro and way too many cars in the garage.
    Burlingame
    The way a car should be delivered
    Feb 23 2004
    yes at the least it should look like this... ;)
    Jan 18 2015
    The piano black trim - is this plastic trim similar to what's on my wife's q5? Or is this trim on a bmw actually clear coated? Wondering if the menzerna can be used on a plastic surface.
    Thanks
    Feb 23 2004
    if it's the piano black trim on the Q5 and its shiny black yes you can use it.
    May 13 2011
    2015 BMW F30
    where are the pictures?
    | Autospeed | JHM | Pure MS
    Senior Member Three Rings AUDITOPGUN's Avatar
    Aug 16 2007
    S3 & Tesla Model 3
    Nice Job
    Established Member Two Rings H60mguy's Avatar
    Sep 03 2014
    MS3 Track Car
    Tennessee
    With that door trim, did you use the 205 on it? I have some issues with my black optics trims on my S4 and have been wanting to correct it.
    Sent from hell
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Is it normal to see that much reaction from the nanolex on paint? Seems like more than i would expect but that may be due to region differences.
    Feb 23 2004
    yes on the piano black trim we used the m205 and finishing foam pads.
