Results 1 to 21 of 21
    May 12 2015
    Homeless
    long discussion Control arm kits
    hey guys, i was replacing my brake pads and i did a quick check on my control arms and they are trashed. I read a huge ton of articles about this topic and i just cant decided, i mean, they say some brand is bad and then they say its good, and then they say it was bad but now the changed it a for a new version and now its good, hell, i im just confused.
    there is three option number one:
    The most expensive one: https://www.fcpeuro.com/products/aud...tro-b7cakitlem
    number two: https://www.europaparts.com/control-...0500085hd.html
    They say this one was bad but now the new heavy duty version its good
    number three: https://www.europaparts.com/control-...-bilstein.html
    ive read that this one is bad, but then its good, nothing concrete, perhaps the user didn't installed it properly, as i read this are elastomeric so you need them to tight them up on a neutral position
    what you guys think.
    Stock Audi A4 B7 V6 3.0 TDI Quattro....
    Mar 24 2013
    Oakdale, CT
    Get the cheap FCP kit, not the one linked above. IIRC, you can get the entire set for less than $300 with the forum discount. I have them and they have been great for nearly 30k miles now.
    -Adam
    Jun 17 2013
    jersey city nj
    The shop that these all the time uses the Meyle brand. Ive never or heard any issue's with them.
    Jun 17 2013
    jersey city nj
    Ive heard that they have a lifetime replacement warranty
    May 12 2015
    Homeless
    good tip, got a link?, to get the discount i just say i am from the forum?
    Mar 24 2013
    Oakdale, CT
    -Adam
    Jun 27 2011
    The fcp group buy is over now.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Mar 24 2013
    Oakdale, CT
    That's a new link from November last year. They started it back up, although I didn't check to see if the discount code still works or not.
    -Adam
    May 09 2012
    Virginia
    I recently got the FCP kit for my B5. They hooked me up with pricing. Lifetime warranty is hard to beat.
    Established Member Two Rings snappytom's Avatar
    May 27 2015
    Wheaton, IL
    I have been thinking about doing a control arm refresh and the lower priced FCP kit looks good.
    Maybe a dumb question ....... is there any difference in these components for the factory sport suspension ? FCP Fitment notes do not indicate anything specific.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by snappytom View Post
    Not for the control arms.
    -Adam
    Jun 17 2013
    jersey city nj
    I think the B7 RS4 upper and lower control arm bushings are made from different material. The part oem part #'s are different from what I re-call. They was stiffer
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by vce1232000 View Post
    The S4/RS4 had all metal tie rod ends as well, but he asked about the sport suspension. AFAIK, the only difference there was the shocks and springs between sport and non-sport.
    -Adam
    Jun 17 2013
    jersey city nj
    .......... I just glanced at his post real .lol
    I still have the RS4 control arms from the BBK I bought. Guess Ill keep them for myself when I need them
    May 12 2015
    Homeless
    yayyyy!, thnx man, one question, im trying to upgrade the whole suspension system, Rs4/S4 uses this one too?
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    On my B6, I upgraded the upper bushings S4 B6 V8 Bushings. The same info should apply to the B7, hopefully my pictures will help to show the differences.
    http://www.audizine.com/forum/showth...1#post11331051 My original thread on this...
    My 2003 has sport suspension, and it has the standard bushings (I always wondered if they used the S4 bushing in the A4's with sport suspension, unless mine were replaced, the answer is no).
    Stock A4 Bushing Center:
    B6 S4 V8 Bushing:
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Kevin C View Post
    I was actually referring to the shore stiffness of the "rubber" bushing insert on the RS4 control arms to the stock A4 one's not the actual metal bushing. I should have clarified that. Sorry for the
    Mar 28 2015
    No worries, I just wanted to point out another way to get a stiffer bushing... Use less rubber and more metal. I have had them in my B6 for a couple of months, so far so good.
    Jun 17 2013
    jersey city nj
    point.... I what your saying
    Sep 11 2009
    A4 B7 2.0T MT, A4 B5 1.8 MT
    South Africa
    B6 S4 V8 Bushing:
    How did you remove the old ones and press in the new bushings?
    Veteran Member Three Rings panman142's Avatar
    Jun 21 2015
    V8_4Runner
    Akron, OH
    I would go with the 034 street density line control arms... Upgraded bushings over stock and substantially less than Meyle HD. I am going to pick up a set soon
    https://www.ecstuning.com/Audi-B7_A4...Arm/ES3046839/
