View Poll Results: Which Setup w/o Buying a New Set?
Voters
3. You may not vote on this poll
  • 20" HRE 840R's (as is)
    0 0%
  • 21" HRE 840R's (step lip)
    1 33.33%
  • 21" Stockers
    0 0%
  • 20" BC Forged HB29
    2 66.67%
Results 1 to 7 of 7
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    Need 3PC Wheel Help
    So I have been offered an opportunity to swap up my HRE 840R's from 20" reverse lip to 21" step lip...
    Stats for the current fronts: 20x10, 32 offset, 2.5" lips. Stats for the current rears: 20x10, 32 offset, 3.0" lips.
    Stats for the new barrels/lips: 21x10, 3.0" lips.
    Suspension: factory SQ5, but will be going to KW HAS in the summer.
    Tires: not sure what will be the ideal fitment for a 10" wheel.
    Colors: I like my gloss charcoal lips. The faces are satin charcoal (matte), will be staying this color. New lips and barrels can be powder coated any color. Leaning towards Daytona Grey color (almost the same as gloss charcoal) lips to match my truck (has HGB package), matte black barrels.
    Started a poll too with my current options. I don't want to buy new wheels, but would lean towards a set of 22" Vossen VFS1 in matte graphite if I had to.
    So wheels experts, please chime in...
    1. What will swapping out my barrels and lips do to my offsets?
    2. Will the new setup fit the SQ?
    3. What is the ideal tires size for this new set up?
    4. What color lips/barrels?
    5. Would step lips look too retro on this setup?
    Thanks.
    FS: Audi TT 225Q Roadster
    Veteran Member Three Rings Pepper SQ5's Avatar
    Aug 25 2012
    MD
    Quote Originally Posted by EYE4SPEED View Post
    Thanks.
    Answers:
    1. As long as you get the same size lips and barrels, your offset will not change.
    2. 21x10 et32 will fit just fine and could possibly even use a small spacer if you really wanted to.
    3. I'd imagine a 275 will fit fine but I'll let the tire pros chime in on that one.
    Jan 14 2008
    Thanks for the reply Pepper.
    Unfortunately, the lips will be changing in the front. Going from a 2.5" to 3.0" lip so the back pad will change the offset from +32 to ?
    Sep 28 2010
    NW NC / DE
    I like the 840s. They'll look every better with a step, and more lip. For the color, I would go full satin gunmetal, or full double tint, in matte or satin. Either way, def stay with the 840, and do the step lip. Really feeling it.
    Aug 25 2012
    MD
    It will go from a +32 to a +26. It should fit still, just more flush.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    About the tires...don't dick around with the 275's. Go with 295/35ZR21. They fit perfectly with my 21x10, ET+30's.
    They also match the stock diameter, which means your speedo/odometer will be correct.
    Based on the manufacturer of the tires you select, you may need some small (3mm) spacers up front, but maybe not.
    Jan 14 2008
    Thanks for the replies.
    If I go 285/35, will I be good without spacers? Luckily I have a set of 3mm, but I didn't run extended bolts. I prefer not to run spacers.
    I saw Mops' many set ups and they look great. Based on those, 26F/32R is pretty safe for offsets right? What are the limits for 285 or 295?
