Results 1 to 7 of 7
    Established Member Two Rings frankvan's Avatar
    Feb 08 2012
    B9 S4, B7 RS4, B8 A4, Cherokee, Sprinter Camper, Volvo XC60 T6, Ducati Panigale
    St. Albert
    Question Rear seat won't unlatch
    The passenger side rear seat in my B7 won't unlatch. I can move the latch (the lever next to the headrest) but it feels like it's not catching anything. I've tried moving the key lock back and forth thinking the tumbler might be stuck.
    I've only found the thread below and he mentions sticking a screwdriver into the bolt side to lift the latch - I can't figure that out because there is no room to fit a screwdriver as there's a plate on both sides that won't let the screwdriver fit in there.
    http://www.audizine.com/forum/showth...t+won%27t+fold
    Senior Member Two Rings Mech_Mike412's Avatar
    Jul 06 2016
    Pittsburgh, PA USA
    I have this same problem with my 2008 A4 at the moment. Any help in fixing it or removing and replacing the unit would be appreciated!
    Sent from my SM-G900V using Tapatalk
    2008 Audi A4 Quattro S-Line 6MT
    K&N Filter - ECS Turbo Inlet Hose - ECS Vent Boost Gauge - GFB Diverter Valve - Morimoto 3000K HID Fogs - JHM Stage 1 93oct - CTS Charge Pipes - Custom Catback, CTS Mufflers
    Jul 06 2016
    Pittsburgh, PA USA
    Bump
    Oct 24 2015
    Perth, WA
    Sounds to me like it is locked. Have a look at your owner's manual.
    My respray thread
    Jul 06 2016
    Pittsburgh, PA USA
    Mines not locked, already tried
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    I have the exact opposite of this problem...mine WON'T latch
    Feb 08 2012
    Dallas, GA
    Quote Originally Posted by drmonkey View Post
    That's easier to fix. Take it apart. It's been so long I don't recall the inner workings, but it's mostly plastic inside. I was able to bend some of it back to make mine work for a while. If it's broken, you'll have to replace the latch.
