Results 1 to 2 of 2
    Aug 19 2013
    minnesota
    Stock smic expansion chamber
    The large aluminum block thing, looks like an expansion chamber under the exhaust manifold bolted to the block... Can I remove this thing with the Apikol side mount intercooler? What are people using to block it off, it has a three-way connection between the tip and the intercooler hose. I'd like to find a to a plastic piece instead of a three way, is there one? I could try and plug it, but with what?
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Remove it and simply plug the hose with a piece of 3/4" dowel rod and a hose clamp. Mine has been that way for years.
    Edit: I should probably add that I made a small bracket that is screwed into the dowel plug on one end and bolted to the block on the other end with one of the bolts that held the Helmholtz resonator in place. That way the boost hose is still being supported the same way it was with the resonator in place.
