Results 1 to 2 of 2
    Established Member Two Rings invncble's Avatar
    Nov 04 2006
    01 TT 08 S5
    Cool Kids Lunch Table
    Audi S5 Sunroof Drain Cleaning
    So every time it rains I am getting water in my drivers side floor board. This happened once before on the passengers side and the dealer just stated they just needed to clean the sunroof drain. Anyone have any experience in cleaning these drains? Im assuming it's something relatively easy and I'd rather just do it myself instead of making a dealer trip for that.
    01 TT
    08 S5
    Established Member Two Rings 49Willys's Avatar
    May 22 2015
    Lake Stevens , WA
    invncble
    I just went through this, first you can try to use some weed eater line and back feed it through the drain buy the front door. But my guess is the tubes are leaking and that will require a headliner removal, Audi fused the connector to the drain hose and that is were mine was leaking. I first thought it was the front pass but it was the rear driver side as well. I used some silicone tape to seal it and so far so good, the removal is time consuming just be patient.
    Good luck Dave
    Mine 15 SQ5 Seapang blue Black optics
    Hers 08 A4 S-line Ti 3.2 trip
    Gone
    06 S4 25 Quattro(oil consumption)
    08 A5 S line 3.2 mt total loss water damage
