Results 1 to 10 of 10
    Senior Member Two Rings nemick's Avatar
    Aug 22 2012
    Indianapolis, IN
    034 Breather Hose Kit for AWM engine
    Has anyone used the 034 Breather Hose Kit? Does it fit? I only ask because I keep seeing posts of 034 silicon hoses not quite fitting correctly and replacing the breather hoses looks like a fairly in-depth job.
    Neil M.
    2004 allroad 2.7T TIP
    2001 A4 1.8TQ, TIP
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    I run their kit on my car and it works perfect
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Aug 22 2012
    Indianapolis, IN
    Good to know. I'll order it up. Thanks.
    Neil M.
    2001 A4 1.8TQ, TIP
    Jan 16 2006
    LA CA
    I also plan to run this soon to compliment the 034 kit. I like to keep as much stock functional as possible.
    http://www.performancebyie.com/integ...t-inlet-outlet
    I will remove the top metal crossover pipe and pipe in a hose to the catch can. Then the catch can to the pancake valve in a closed loop system. No smell for me.
    Aug 22 2012
    Indianapolis, IN
    Sounds like a great plan. I'd be interested to know how it works out.
    Neil M.
    2001 A4 1.8TQ, TIP
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    I have one , it is good quality but expensive for what it is.
    I made a setup for 42dd catch can out of silicone and a few fittings(cost ALOT less and does the same job plus I got to route it as I wanted)
    Orange County, CA
    Quote Originally Posted by nynoah View Post
    Same, no issues.
    B5 Parts For Sale
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    pretty sure its only the turbo inlet pipes have fitment issues.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Aug 22 2012
    Indianapolis, IN
    Quote Originally Posted by King_ View Post
    Good to know. Thanks.
    Neil M.
    2001 A4 1.8TQ, TIP
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    It fits just okay for me, a little off but still works well enough.
    The thing I dislike the most with 034's silicone is how vapor seems to leech through the silicone, and sort of condense as liquid on the outside. This causes the silicone to trap dust whenever the belly pan is off the car.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
