Results 1 to 40 of 79
    Dec 16 2014
    Irvine, CA
    2002 Allroad Project
    Finally got home from California picking up my new 2002 Allroad. Had to drive 22 hours straight to texas. What a pain.
    The car is a 1 owner 2002 Allroad 6MT. Winter Package, no bose. 106K miles. Car is in good shape cosmetically, but will need a few things mechanically to make it perfect.
    Suspension / tires first. The air suspension system works, but half the shocks feel blown, every bump I hit the car rolled side to side badly. No leaks in the airbags and some have been replaced in the past, but the shocks are all original. Currently the car feels horrible in the handling department. The tires are beyond bad as well, car has a bad shake over 75mph, but 2 tires are at like 0%, so I am sure everything is out of balance. I will probably get full arnott gen 2 setup and hoping maybe to get some revalved bilsteins if I can figure out what valving will work best, since I really like the air setup and would like to keep it. Control Arm bushings have seen better days, so I will replace all of them.
    Engine is in good shape, turbos spool good, no codes. I am sure there is a few leaks from seals from age alone. So I will do full timing belt / water pump / VC gaskets and cam seals. Transmission shifts good, clutch fine for now.
    Interior is clean, but i need all new cup holders since none of them work right. Need Door Panel Cubby, since one does not close. Needs new light switch panel, since this one is peeling. Radio is a total mess, will need new speakers and I will probably replace the entire head unit, since I want Blue Tooth / Airplay streaming. Car came with all weather mats and brand new original mats. Roof rack attachement and Ski rack.
    Here are some pictures, car is dirty from 1500 miles on the road.
    Veteran Member Four Rings SteelyS6's Avatar
    Oct 29 2011
    Winnipeg Manitoba
    Congrats, does look like a very clean body!
    Jul 18 2009
    D2 S8, E61 535xi, B5 S4
    Subdivisions, NW burbs
    Nice pickup. For handling, the hotchkis sway kit really tightens up the turns imo. It is still a heavy pig but I really liked the addition to mine.
    Veteran Member Three Rings JTown77's Avatar
    Feb 01 2010
    2002 S6 red, 2003 2.7 allroad stage II blue, 2005 4.2 allroad silver, 2003 FLHRCI
    Charlotte N.C.
    Arnott makes some shocks, but I saw little improvement over my 131k oem shocks. Where is Bilstein when you need them?
    I have a rosstech vcds HEX-USB+CAN Interface and cam lock bar to rent with deposit in the Charlotte area. Like all C5 owners I am looking for local parts!
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Good job, awesome find. Plus shes not a swap!
    Dec 16 2014
    Irvine, CA
    Need to finish my other project and get it out of the garage before I can start on the Allroad. My other A6 needs new 1st gear collar, transmission won't go into 1st. It also needs all new gaskets, since its leaking from everywhere.
    Spent today building Wheel Cribs. Was going to buy some, but 12inch ones sell for $150 for a pair! $20 buck of wood and I had 2 built in an hour. Need more 2by 4's so I can build other 2.
    Jul 18 2009
    Quote Originally Posted by JTown77 View Post
    Ya, I agree. I should have kept my oe shocks when I replaced with arnott gen2. I dont love them. And bilstein was in mix but widly held as even worse with their allroad offerings.
    Dec 16 2014
    Irvine, CA
    Is anyone happy with the factory allroad suspension? Is it worth fixing? I rarely go offroading, so I am not sure I really need ride height adjustments. I have been researching upgrades for the factory air setup and no one really has anything worthwhile, everything is a compromise. I am either just going to replace all the shocks with factory versions and replace the control arms, or just install coilovers with A6 bits and pieces. Would help to get a ride in a car with good factory suspension so I can see how well it runs.
    Jul 18 2009
    If I had it to do all over again, I would havd ponied up for factory replacements. Shocks for certain. The current and likely only aftermarket offerings just dont cut it. I liked my original factory ride much better than the arnott gen2 air springs and shocks (front). May very well ditch them and just buy new factory components. My front air springs were leaking and needed replacing.
    For me, off-roading or not, the allroad is equipped with the air suspension. I dink around with it plenty and love it. Even just in and around town although I do take it camping, hiking, fire roads, mountain biking, skiing, etc...I find it a useful function even if it is finicky to say the least.
    Dec 16 2014
    Irvine, CA
    Anyone install this kit? Pricy, but specific to the allroad.
    http://www.2bennett.com/allroad_suspension.html
    Dec 16 2014
    Irvine, CA
    The rear factory shocks are stupid expensive. $500 each, anyone have a OEM replacement? I know Arnott makes OEM fronts, but no rears, only bilsteins which don't look good.
    Jul 18 2009
    And thats on sale. Lol!
    And Arnott are not on par with oem imo
    Aug 04 2009
    Glen Ellyn, IL
    Quote Originally Posted by happy2B5 View Post
    X2. Arnott on my tip allroad: blahhh OEM on 6-speed and 402'd to hell and back? Very nice.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Feb 01 2010
    Charlotte N.C.
    I put Bilsteins on my truck a few years ago and they were 2-3 times better than the factory offerings, I wonder what was the problem with their audi fitments?
    Oct 29 2011
    Winnipeg Manitoba
    Don't buy Arnott shocks, one of mine was blown after 13 months. Went back to OEM and the ride is definitely better.
    Jul 18 2009
    I dont think its all audi fitments. Just allroads options I guess. I have pss9 on an s4 avant and love them.
    Dec 16 2014
    Irvine, CA
    From my research the rear bilsteins for the allroad are a A4 application, no custom valving of any kind just off the shelf shock with collar to work with the air spring. It is way under dampened and floaty due to the car being way heavier.
    Jul 18 2009
    From my experience, you can get away with arnott air springs. Just pay up for factory shocks if you wish to keep the air system (which I do).
    2bennet or blauparts for allroad specific coilover system. But I like the versatility of the push button system.
    Sep 30 2015
    The only thing i like about my blaupart shocks for my a4 b5 are the fact they are limited lifetime warranty. I guess it depends on where you live but still, a set should last 50-60k. I had to replace my rear set already at 20k. Thanfully they paid for it, but maybe I should have just bought Oem, which i will next time.
    Feb 01 2010
    Charlotte N.C.
    Quote Originally Posted by Kaane View Post
    THIS, I think that is the issue with the Bilstein fronts as well, they were designed for another fitment and they just slapped a collar on them.
    Feb 07 2008
    The boonies, near Seattle
    My recommendation is to stop spending money on air suspension parts before you start. Convert to standard a6 suspension and be done with it. Cheaper control arms when you need them too.
    -dre
    Established Member Two Rings BasicA6's Avatar
    Feb 16 2016
    Puyallup, Washington
    that all road is super clean.
    Dec 16 2014
    Irvine, CA
    Replaced couple things that needed to be fixed asap. New Headlights switch and New Cup Holder :) Now I need to figure out what to do with the AC control buttons peeling.
    Dec 16 2014
    Irvine, CA
    Anyone know if the earlier non soft touch climate control have the same wiring? Is it plug and play?
    Dec 16 2014
    Irvine, CA
    Installed another cluster with a working LCD panel. Used Vag K Commander to sync to immobilizer and change the mileage.
    Got a Stage 1 Tune from Daz and flashed it with nefmoto.
    I got a stupid transmission error in the cluster, anyone know how to clear it? It still thinks its in a car with an automatic. I don't see any coding option in the cluster for manual transmission.
    Dec 16 2014
    Irvine, CA
    I ordered 19x10 square wheels. Original plan was to run 275/35/19 square setup, but I am worried about the front not fitting. Anyone run 275 fronts with no issues?
    how about 275/35/19 rear and 265/35/19 fronts?
    Jul 18 2009
    Wheel et?
    4rings has run 275+ I believe.
    I run 265/40r18 on a 10 wide wheel at et13. I am very close to uprights and doubt I could run a 275. But, I want to try next tire run.
    Feb 07 2008
    There is an option there somewhere. Can't quite remember where but it's in the cluster coding.
    Yes, but the off button doesn't work as it's the econ button on the soft touch ones.
    My last allroad I converted to all prefacelift plastics and had zero issues. It's a bit of work but screw soft touch.
    -dre
    Dec 16 2014
    Irvine, CA
    19x10 Et25, I am sure I will get some spacers as well. I might run 255/40/19, not a fan of stretch tires, but the wheels only come in 8.5 or 10, nothing in between.
    Daz told me how to fix the adaptation in the cluster. I am going to copy the adaptation from fields 60,61,62 in vcds from old cluster. They control the CAN gateway functions and specify what CAN equipment is on the bus.
    Dec 16 2014
    Irvine, CA
    New Wheels arrived, picking up tires later today. Ordered some red center caps as well. Waiting on some spacers, ordered 10mm and 3mm spacers.
    19x10 Rotiform SPF 25mm offset.
    Oct 29 2011
    Winnipeg Manitoba
    Nice wheels! May want to go wider on tire if you don't want stretch, I'm running 255/40R19 on 9.5 wide TSW and they are stretched.
    Aug 04 2009
    Glen Ellyn, IL
    Facelift and pf climate units are non-interchangable. I'm 285 in the front now. 285/30/19 9.5 wide and et12.8, required flare modification.
    (shhhh, I'm secretly working on a wider bolt-on allroad flare in carbon fiber. Also working on a bolt on flare spacer allowing 285 square for those that don't want to pony up for the entire flare. Both will be able to be run together for much wider track. Hoping to have this done for camp allroad to show and take orders from anyone interested. Sort of keeping it dl but I also want to gauge some interest.)
    Check your alignment before assuming your struts are done. Toe comes out pretty easy and can give a really unsettled ride.
    @fourings | Build
    Dec 16 2014
    Irvine, CA
    Quote Originally Posted by SteelyS6 View Post
    I've ran 255 on 19x10 before, so yep they will be stretched, I am worried 275 square setup will rub in the front. I will probably get different tires once I install coilovers and measure exactly how much room I have.
    Aug 04 2009
    Glen Ellyn, IL
    275 won't rub if the offset is correct. Guaranteed.
    @fourings | Build
    Dec 16 2014
    Irvine, CA
    Quote Originally Posted by 4rings2turbos View Post
    You 100% certain? I was about to go buy tires. I have 10mm and 3mm spacers coming. So I can go down to 12mm offset front. Do I need more spacer? So 275/35/19 square should not be a problem?
    Aug 04 2009
    Glen Ellyn, IL
    I'll put it this way so I don't get myself in trouble :)
    Front specs before buying new spacers:
    19x9.5 et17.8 285/35/19. This does not clear the upright, the tire rubs. But it clears the flare. I need approx 5mm more to clear the spindle. So if I had a tire with 10mm less width then it would give me that 5mm clearance on the inside.
    Crucial to this argument is that Pirelli has some of the absolute widest treadwidths of any manufacturer or model- section width is uniform for the most part given a tire size, but the treadwidth varies. If you're going with a Michelin you will have miles of clearance. All the different Michelins I ran in 275 had a similar treadwidth to my P Zero and Ecsta SPTs in 255. If you get a P Zero, especially Corsa or Trofeo R like me, it will be tight. Michelin or Conti? Even more room for activities.
    @fourings | Build
    Dec 16 2014
    Irvine, CA
    Tire in question is Bridgestone Potenza S-04 my favorite all around tire.
    - - - Updated - - -
    Should I get 265/35/19 to be safer?
    Aug 04 2009
    Glen Ellyn, IL
    The Pole Position is a nice tire. The 275 is a whopping 1.4" more narrow than the 285 P Zero in treadwidth and .8" more narrow in section width. I really think those will be just fine as long as it's spaced out from the upright.
    If anything a 265/35 rolling diameter is going to look and be too small. My 285/35 is still smaller than factory rolling diameter.
    @fourings | Build
    Aug 04 2009
    Glen Ellyn, IL
    Also a 265 on 10" wheel is going to be more stretch than flush. Short sidewalls plus stretch on an allroad doesn't look right.
    @fourings | Build
    Dec 16 2014
    Irvine, CA
    285/35/19 = 26.854 factory is 225/55/17 = 26.744, so 285 should be a bit taller.
    275/35/19 = 26.579 is pretty close.
    ok, I'll order some 275's worst case scenario, I'll replace the 2 fronts if they rub.
