Results 1 to 35 of 35
    Deactivated Three Rings
    Aug 24 2015
    Traction control EMBARRASED me today. Twice.
    True story. I was stopped at a light, some car wanted to toy with me in the right lane (after you read the story, this could have been ANY car.) Light turns green, I floor it, I go for 1 second, then I feel like my stomach hit the steering wheel...car loses power....I'm jamming the gas pedal, but nothing. Meanwhile, this car on the right just takes off and I feel small. What the hell?!!? Then it happened again later in the day.
    I'm afraid to turn off traction control because the 1 time I did that it was raining and I went to turn left from a stop sign and spun out nicely almost 90 degrees. Thank goodness there were no cars, but still. In a straight line, is it ok to turn off TC??!
    ridiculous.
    Jan 18 2015
    Yes
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    In a straight line.. Just turn off the first one, don't hold it down for 3 seconds so you'll keep the esp on
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Sep 05 2012
    It happens, but can also be wrong tires for the season, or tires just starting to be worn out. Maybe that?
    Established Member Two Rings pfft's Avatar
    Jul 24 2014
    '05 Nissan 350z
    Grand Rapids, MI
    I've never heard of traction control doing that. You shouldn't lose power completely. Then it happened again later in the day...hmm, I'd get that looked at.
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    Quote Originally Posted by pfft View Post
    This.
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    I've had traction control totally take away all of my power, that's why whenever I do straight line pulls...I turn off the first stage of traction control.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    It will if your modded and go balls out on less than warm dry roads. I've had the exact thing happen to me. Car will bog down like it's being strangled. LOL though.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Four Rings Wusty's Avatar
    Mar 07 2010
    '17 C63s AMG
    What tires are you running? I hope the story doesn't include "There was snow on the ground, and I'm running summers."
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    It's very salty here also (which can be slippery) and I can get the wheels to spin on hard launches (which I don't typically do) with snow tires. That being said, they never spin to the degree that TC fully intervenes - typically it will reduce power just slightly... If you have reduced traction (summer tires in winter or crap/worn all seasons) and you're really spinning the wheels then yes you will get the full lock down of TC...
    As everyone else mentioned, you can always just hit the ESP button and disable the 1st level which will allow your wheels to spin... good for launches... or you can just adjust the amount of throttle you are giving for the conditions... you know, the throttle has more than 2 settings
    Finally some words of wisdom - A good drive knows what the limits of his/her tires are given the road conditions of the road and weather - it shouldn't be a surprise to you when TC kicks in, rather you should actually be able to anticipate it...
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Twice in one day? Are you on summers, UHP all-seasons, or bald tires? Otherwise you could have an issue with your traction control if you are on winter/snow tires.
    I have had the back end come out twice in turns but TC never intervened, and I was still on the gas.
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    maybe its your supercharger getting confused upon WOT ...
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Senior Member Three Rings TomPaul10's Avatar
    Aug 04 2014
    albany, new york
    Quote Originally Posted by vwblackb5 View Post
    This.
    Current: 16 mythos black S6 prestige
    past:
    13 S5 stage II+ awe track/ H&R
    2016 SQ5
    2016 Sepang S3 premium
    2010 Ibis White S4 P+ / A.W.E Track /
    2010 Stage II A5 / G.I.A.C. / A.W.E. / H&R /
    Jan 18 2015
    Quote Originally Posted by The Fat Kid View Post
    TC won't intervene like this in a turn unless there's zero grip, just esp and sport diff if you have it.
    I can trip my TC pretty hard in a straight line. I'm running factory pirellis in sunny SoCal with dry pavement. When TC engages, it does so very hard. Happens more frequently in the cooler morning air and I'm running a CW but it would happen from time to time when I was stock. I imagine stage 2 guys have to disable their TC every time they play stop light warrior.
    Aug 24 2015
    Thanks for all the replies. Yes, I should have clarified a few things.
    When I lost power, I mean the car was still moving forward but slowly...I wasn't completely stopped. A few seconds later I was able to keep going. The weather was dry but CAF (cold as F...) as the NY/NJ area had the worst freezing temperatures in like 50 years. Anyhow, I'm not that crazy lol...I am on dedicated tires (got them 1 week after TG, but you remember the crazy warm months we had in the beginning of winter here.) I have DUN Winter Maxx (http://www.tirerack.com/tires/tires....Premium%20Plus) I think they were like the mid-point on the price range IIRC.
    Lesson learned - EASE into the Pedal next time AND start turning off that 1st stage of the ESP (and remembering to reactivate it when done!)
    Mar 10 2015
    New England
    Winner!
    Quote Originally Posted by Rocket Tech View Post
    Once was on black ice with Blizzak WS80s and all four wheels lost traction in the turn. Still no intervention from any nanny devices.
    Edit to add: Yes, I do have the sports diff
    Your scenario is exactly why I asked about tires. Summers, and even some UHP all-season tires, get hard and lose traction as temps drop. The OP is in NY and could be on the wrong tires.
    Oct 20 2014
    United States
    Or just turn tc off when it's not raining or bad conditions
    Current: 2013 Audi A4
    Sold:
    2015 F83 BMW M4 OEM + (Lots done but not too much lol)
    2014 Phatom Black S4
    Mods:| Unitronic Stage 2 | 19x10 Rotiform Ind-T Chrome stepped lip with brushed Aluminum faces | Avery "Dark Grey Gloss" vinyl | Airlift Performance Bags | Autopilot v2 | 5% tint, APR Stage I + II Intake | Carbon Fiber J-Codes | AK | USS system | Miesterwerk SS | Deval Front Lip | AWE Non-Res DP's | AWE Track Exhaust |
    Aug 24 2015
    LOL....good one :)
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Traction control with absolutely do this if u break the tires loose. To those saying to get the car checked out you dont know what you're talking about.
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
    Mar 10 2015
    New England
    Quote Originally Posted by Whitee View Post
    He made it seem that the car was almost coming to a complete stop in the original post - "I feel like my stomach hit the steering wheel"
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    Probably just his nuts receding inward from the embarassment. :)
    Aug 24 2015
    Quote Originally Posted by Pared View Post
    It was embarrassing alright :(
    Sent from my iPad using Tap,Tap,Tapatalk
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Compared to my B7 A4, the traction control on the S4 is completely non-invasive. The A4 would yank all power from the wheels under pretty much any scenario. I am very impressed in how much more fun the S4 will allow you to have with traction control on. You can get a pretty decent drift going add long add your wheels are turned in the proper direction of movement. That being said, I still drive with TC completely off quite a bit of the time. OP should probably do the same to get to know your car a little better. You'll never know the car's true limit of you don't actually test it.
    2021 Audi S4, P34 Intake
    Senior Member Two Rings roadawg's Avatar
    Jan 09 2015
    Interesting, I absolutely hammered the gas today from a stop up a hill and the car shimmied a little in the rear and took off.
    It's 14 degrees outside, salt covered roads and I am on really shitty half worn all seasons.
    I've never experienced like what you are describing, it almost sounds like something other than traction control. <shrug>
    2012 S4 - Man pedal, sport diff, APR tune, Meisterwerk SS, AWE Exhaust & other goodies.
    Aug 24 2015
    Quote Originally Posted by roadawg View Post
    Interesting. Thanks for sharing.
    Mar 06 2015
    Columbus, Ohio
    Sounds like you're stock. Stage 2 would spin hard and bog with the TC light flashing repeatedly .
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Oct 20 2008
    Denver
    Quote Originally Posted by S4NJ View Post
    ridiculous.
    Do you have ADS? if so did you put it in dynamic AND tc off? sounds like you had a bad launch that ended up canceling out.
    Aug 24 2015
    Quote Originally Posted by AudiTFSI3o3 View Post
    I think that's what happened; I was in dynamic mode with TC on. From now on, I'm going to turn off TC (not all the way of course.)
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    That's exactly what it feels like, the car takes off like a rocket for a second and than basically feels like you hit the brakes
    Established Member Two Rings ZChicagoS4's Avatar
    Nov 02 2013
    Chicago
    Odd. 10 degrees here and in a straight line my Stage 2 + DSG tune + Intake has no problem hooking and enjoying the cold air. (All-season peelers)
    2015 Audi S7 Prestige. Bang & Olufsen, Black Optics, Night Vision, Driver Assistance, Adaptive, Alcantara Headliner, Pre Sense, Lane Assist, Cold Weather, etc.
    2017 Jeep SRT. Borla ATAK.
    2017 Wrangler Unlimited Hard Rock
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by ZChicagoS4 View Post
    If you have full nanny controls ON and can do that without TC Bogging you then I would be more concerned about your situation due to what would be a lack of power.
    Jan 09 2008
    Winnipeg
    My B6 S4 was like this too. If the tires started to slip but you dipped even more into the throttle it would cut even harder to the pint that it felt like you were just at idle. My B8 S4 is not nearly as bad, sure it could be a little more forgiving but generally it's fine. I usually hit the stage 1 deactivate if I want a little more wiggle room (pun intended).
    Apr 04 2012
    MSP
    +1... My B6 was really bad also.
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by MrFunk View Post
    It was to the point I never left TC on. I would always turn it off. Nothing like trying to merge and losing all power because of a little sand or something. I've found that as long as you power through in the S4 and maintain 100% control, TC will mostly leave you alone. However, give the car even a sense that you can't handle it, a slightly wrong steering angle, touch the brakes or let off the gas, and it will "save" you. ..
    Jun 26 2012
    Rockford, il
    It's completely normal, mine does this too, especially if there's a little salt on the road or anything that might break it loose. I can easily spin all 4 wheels when I hammer it with the TC off. Next time just turn it off and away you go. I've found a lot of VAG cars have the same type of TC where it cuts power completely and this is my 7th VAG vehicle.
