Results 1 to 2 of 2
    Aug 19 2013
    minnesota
    Engine management fuse 29
    Coil and injector harness are defective. They crack all over and short engine management fuse 29. The correct replacement fuse is a 'Littlefuse' 287 ATO aka ATOF 20 amp. ATO 287 supercedes ATO 257. I got 120 piece assortment on ebay for around 5 bucks shipped. http://m.ebay.com/itm/New-120pc-Blad...ATCHING_ACTIVE. Littlefuse has a good website, http://m.littelfuse.com/products/fus...ade-fuses.aspx
    Arm yourself.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Thanks audizine
    Sent from my SM-G935V using Tapatalk
    Using Tapatalk
