ok here goes.
Recently had some misfire issues, threw P0300, so went ahead and did a full tune up on the car. New plugs (PRF6Q, gaped at.024), all new coil packs, oil, of and af. After that the car ran great, no issues going into boost, would peak nicely at 17 psi whenever needed. Three days ago I was driving home from work behind some slower individuals, made sure the car was up to temperature, threw it into 3rd and went for it. Only boosted to 12psi and was holding strong there, shifted into 4th then heard a small pop. Car immediately acted as if it was misfiring again, checked my review and behind me was the thickest trail of white/gray smoke. I limped my way home with cars avoiding being behind me due to my new lovely tail. Scanned the car with my VAG COM tool and it had 3 miss fire codes, all for cylinders 1, 2, & 3. From there I swapped the ICM's, cleared the codes and checked the Live Data and it still showed the same three misfiring. let the car idle some more and had two new codes pop up.
P0134 B1 S1 Oxygen sensor no activity
P0139 B1 S2 Oxygen Sensor Response too slow
Car was still misfiring and still spitting out the latest cause of global warming. Shut it all down last night after getting my Live Data recorded and saved. After extensive searching on here I went back out to start checking things out, I noticed that there is a nice little ring of oil sitting under my exhaust tip with a drip of oil sitting waiting to fall. Checked my spark plugs, for Bank 1 and all look fine, (will be grabbing an inspection camera from work on Monday), also checked my Coolant Reservoir and it is about 2 inches low, and my oil dip stick is dry.
I've spent about 2 hrs searching on here to see if anyone has had the same issue, and have not had any luck. All day I have been hoping it is going to be simple sensor but now after all of my searches and the status of my car, I fear I will be tearing the heads off soon.
Advice?
