Results 1 to 31 of 31
    Established Member Two Rings afstud's Avatar
    Aug 14 2010
    06' A4 2.0T Quattro, 05' BMW X3 Sport 3.0, 86' BMW 325e, 09' A8 4.2 Quattro
    wisconsin
    Timing chain tensioner questions.
    So i just purchased a 2010 A4 with 94k on the clock right now, its a clean 1 owner car always maintained at the Audi dealer and oil changes religiously done every 10k by the same audi dealer, i talked to them and they told me he was very loyal and took very good care of the car, it did have the oil consumption test done at 44k miles and they did the stage 1 repair and it fixed everything and he never had any issues after that. the audi dealer did replace the turbo at 70k miles and a few other things. I want to make sure this car keeps a great track record and keep it in the shape its meant to be in, in keeping up with maintenance items ive just recently done the coils and plugs with ECS upgrades, i also will do a carbon clean soon along with a few other normal maintenance items that should be done around 100k miles now ive been reading that this tensioner issue has been causing catastrophic failures and i want to get ahead of the situation before it becomes a problem as i do drive 60 miles round trip for work, this is not my primary car as i do have a 16' Buick Regal GS that im leasing but its more a winter car and fun cruiser. My car starts up very smooth and doesnt have any clanks or ticking noises like some do that ive heard. its very quiet even if i let it sit for days is this a good sign that my tensioner is ok for now ? i was planning on doing the whole timing chain guides etc within the next couple months, thoughts?
    Senior Member Two Rings MrTylerRaines's Avatar
    Feb 21 2015
    Ohio
    Mines in getting new pistons as it failed stage 1 & 2. Im having them do my upper timing chain and Tensioner. Yes i highly recommend doing it. Theres been a big revision with the tensioner since our 2010's were manufactured.
    Aug 14 2010
    wisconsin
    i just read another new thread of the guy where his snapped this winter.. god that scares me to even drive this car until i get it fixed guess ill stick with driving the GS until then
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Get it done when you do the carbon clean out, it shouldn't cost much while they're already in the engine. Most of the issues that I recall seeing were well over 100k miles, so I don't think you should lose sleep over it.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Senior Member Two Rings Demringstho864's Avatar
    Sep 26 2015
    Syracuse NY
    I'm in the process of pricing everything out on mine. Is there any special tools I will need ? I have done plenty of timing belts and chains. but never did one on a VW or Audi.
    2009 A4 2.0T Quattro Premium Plus
    Static dropped on 20s, lots of bolt ons, and some appearance stuff
    Aug 14 2010
    wisconsin
    Quote Originally Posted by Demringstho864 View Post
    wondering the same thing, i dont have much time on my hands anymore with work so im sure ill have to farm it out to one of my techs at work, I would prefer to do it myself but o well, can only do so much. ive done a timing belt on my b7 so i wouldnt think it would be much harder than that, but correct me if im wrong.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    You need two tools :
    T10531 (about $150) to prevent the timing chain sprocket jumping alignment when the crankshaft pulley is removed.
    T10355 (about $40) to counterhold the crankshaft pulley when the center-bolt is removed and installed.
    Apr 24 2013
    Canastota, NY
    I did mine when I got stage 2 oil consumption done. Cost me $250 and peace of mind...get it done
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    Quote Originally Posted by MrTylerRaines View Post
    Correct, there have been 6 different revisions since 2009-2010's. The latest revision, which ECS, Europaparts and a few others do have/carry (I've verified).
    Quote Originally Posted by Project Quattro View Post
    It will cost a good amount as the whole front of the car has to come apart to properly do this job. Carbon cleaning is easy compared to this; only the intake side of the motor has to come apart (charge pipe, intake manifold and throttle body).
    Technically speaking, the tensioner issue could fail almost at anytime because of how poorly designed it is. However, there have been confirmed cases from 60k and on up; much more common and prone from 80k and higher. The abuse to the flaw occurs on startup only of the engine, not during normal operation.
    Yes, there is a kit - I'll explain shortly.
    Quote Originally Posted by afstud View Post
    If you've done a B7 or even any other car's timing or even 'core' engine work, this isn't a job that cannot be tackled. You just need the special tools and the procedure. I'll explain shortly...
    Quote Originally Posted by S4'ed View Post
    You need more than those 2; I'll explain shortly...
    Quote Originally Posted by MaXaZoR View Post
    That's even high since literally the whole motor had to come apart to R&R the pistons. If you said $150, I could see that being an 'ok' price. Was 'only' the tensioner replaced?
    Not sure if you guys have seen my situation, but check it out:
    http://www.audizine.com/forum/showth...-Now-with-Pics
    My tensioner failed on me with almost 110k on the car. Thankfully I didn't have catastrophic damage; I was lucky.
    I have a lot of details in that thread along with pictures too. I need to update it with more and will once I complete this reply
    From my thread (I'll quote myself), you will need the following tools:
    I've ordered this kit: http://www.toolsource.com/cylinder-t...-p-150767.html; it's pretty complete for what you'll need.
    I went ahead and got these too: http://www.toolsource.com/locking-audi-p-99938.html. I'm sure I could have found some picks and small screw drivers that might have done the same thing, but for a few more bucks, I got everything I would ever need.
    If you want to take the head off then you'll need this one too:
    I also ordered the head bolt bits: http://www.toolsource.com/audi-head-...-p-114980.html. After reading up on the MK6 forums, it seems normal torx bits are not the best. I'd rather not screw anything up.
    In the timing kit you will get the following tools:
    ¤ Central Valve Assembly Tool (T10352) - This is required to remove that valve assembly on the intake cam
    ¤ Counterhold - Vibration Damper (T10355) - Required to hold the crank pulley into position (not only hold it toTDC) while untorquing and removing the crank bolt
    ¤ Locking Pin (3 pc.) (T40011) - Not really required, you could use picks or tiny flat head screwdriver possibly. This set is only like $15 so its worth getting, IMHO, instead of hunting and finding some type of tool that will work instead
    ¤ Tensioner Locking Tool (T40267) - This locking tool looks like its for only the newer style tensioner. I'm not 100% positive on this, but this tool holds the tensioner's piston in place
    ¤ Camshaft Locks (T40271) - I would almost designate this is a requirement. There are 2 cam locks, one for each cam. These holds the cam sprockets in place and really help with removal and installation of the components. It will greatly help you with holding proper timing on the cams too upon re-installation.
    ¤ Camshaft pins - T40196 - required; you place these into certain bores, once the cam actuators are removed, then crank the whole engine over 4 times to ensure that the exhaust lobe pairings, per cylinder, are in correct positioning to avoid valvetrain damage.
    ¤ Crank spacer - T10368 - I would highly recommend this and would put it to required. Once the crank pulley comes off, the face splines on the crank are exposed. These splines are very shallow and unique; the spacer is placed in front of them and the crank bolt is screwed back into place to hold the spacer on the splines to protect it while you work on the front cover removal and all the timing setup.
    ¤ Chain Tensioner Lever (T40243) - This isn't required and is kinda costly. It isn't included in the kit I mentioned above; it does make the job easier but you can figure out other means to remove tension from the timing chain.
    Hope that helps gents.
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Sep 26 2015
    Syracuse NY
    Thank you for the very very helpful post. I have some additional questions my self. I'm hoping somebody will chime in and put my mind at ease. Because my anxiety is starting to take over. What is the main issue with the timing on the tfsi. Is it just the tensioner ?? Does the chain stretch ?? Should I replace everything or just the tensioner ?? I plan on having this car for quite a while. And I have one of the very few 09s without oil consumption issues. I'm in the process of doing a carbon cleaning. I brought my car in for a p2015 code to the dealership. They confirmed it was the intake flap. But since the service department felt like being douchebags. And my car being slightly modded. I now have TD1. So I'm between a rock and a hard place. I'm rather mechanicly skilled so I don't have a problem with taking on anything. But this is my first Audi. And I'm going to be honest. I'm slightly intimidated.
    Aug 14 2010
    wisconsin
    i would also like to know if i can get away with just doing the tensioner or which chain is the most prone to failure? does anyone have an idea of what this would or should cost from an independent mechanic to have done? i was thinking of having them do this and a carbon clean at the same time.
    Sep 26 2015
    Syracuse NY
    I have been quoted anywhere from 2500 to as much as 3700 dollars to have it done. I said I will take what you guys are smoking. Because that much be the good stuff
    Aug 14 2010
    wisconsin
    wow that seems way beyond high im thinking like a grand tops
    Sep 26 2015
    Syracuse NY
    730 is the cost for a complete timing chain kit
    Jun 26 2009
    Bremerton WA
    The timing chain as well as the tensioner has been revised, the new chain is much beefier. I was able to get by with just buying a new chain $89 and tensioner $59. I only used two special tools. The T10352 (there are different versions of this tool) for the cam bridge and T10368 crank spacer. Both can bought for around $50 total. For early years the cam bridge has a screen that likely fails. Its worth checking out while there. You may want to replace the guides but I didn't they looked good upon tear down. I recommend permatex ultra black RTV sealant for timing cover reassembly. Its an oil resistant sealant and unlike an anaerobic sealant if you tweak the cover plate a little it will still seal. I did wish I had a crank pulley holder but was able to make due with a strap wrench. Granted without the timing locks I did have to wind the intake cam back as it will spring fwd due to valve spring pressure.
    VMR 710's, APR software, Eurocode HFC
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    I don't think you will find any data on the frequency or failure time for these parts yet...just the experience of a small number who have posted here. Here are my thoughts. If you have the old tensioner, it should be a priority repair, IMO. It seems like it's more of a question of when, not if it will fail. From the pic's you can see the problem component in the tensioner is a small piece of stamped metal worth pennies. The consequences of failure are severe however, and can be far worse than Allowencer experienced with bent valves, damaged pistons, etc.
    This is only my 2nd vehicle with a chain. I've done tensioners and belts a number of times but never had to replace a chain yet. That doesn't mean my A4 won't need a chain however. My reading has shown that chain does wear over time, usually with the link pin connections enlarging, causing the chain to lengthen. As some point this may cause some issues with the engine not running as well as it should. And it could get bad enough to do more damage but I don't any specifics for our car. It's also possible for a chain to break, but this seems uncommon. The revised chain appears to be more robust. So, it would probably make sense to do the chain while the front is apart, particularly if the mileage is high.
    I had the tensioner done with the stage2 fix and in retrospect wish I had also done the chain.
    2011 A4 Avant
    Aug 14 2010
    wisconsin
    i see most people are just doing the tensioner and the upper chain instead of all of them... anyone else have a price that has had it done?
    Sep 24 2014
    Central NJ
    T10368 has been replaced with T10351. The old tool often failed to maintain the sprocket timing : when the crank pulley center bolt is removed, the timing often jumps before you can install the T10368.
    Jun 26 2009
    Bremerton WA
    I can see where it could easily happen. The crank timing gear uses the same spline type where it mates to the crankshaft as it does to the crank pulley. If it loses orientation you can have a motor that looks to be timed correctly (using the timing chain colored plates and arrows) but will still have valve/piston contact. A guy on VW vortex had this happen.
    Aug 14 2010
    wisconsin
    so i do the tensioner and which chain? i see theres a couple of them, do i just have the top one done?
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Sounds like doing the top one with the tensioners are the way to go?
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Quote Originally Posted by Allowencer View Post
    The tools that you bought to do this maintenance. Would you be willing to allow other members to borrow/rent/buy them from you to do the same for their cars? I know of at least 4 other members who want to do this.
    My 2009 A4 Prem+ Build thread
    Sep 24 2014
    Central NJ
    The minimum job is to just replace the lower tensioner. If you have had regular oil changes, at not more than 5000 mile intervals, and have used the correct oil and filter, then I would not worry about any of the chains, guides, or other tensioners.
    Jun 12 2013
    It is primarily just the tensioner. If you go to my thread, I explain what specifically fails and my thoughts on 'how' it fails.
    Yes the timing chain stretches, but this is to be expected and is 'normal'. Audi does state that the chain should last the life of the vehicle - I would tend to agree with that based on how the chain is built. There has been a revised one which the links are beefier; might as well get the new one too. If you're mechanically seasoned and are comfortable doing 'core' engine work, this is a job is possible to complete in a weekend with all the proper tools (depending on how efficiently you work).
    As I mentioned above, the tensioner is the key component that NEEDS to be replaced. My thoughts are, if you're in there and that far, you might as well replace all the other timing sets and guides as they all wear together. By the book you're looking at 6.2 hours to R&R the chain so take that and multiply it by the shop's rate (prolly $110 an hour'ish?); so you're looking at $700 in labor at least alone.
    I can't believe those prices for sure. The whole front of the car has to come apart (bumper, headlights, intercooler, A/C condensor swung out of the way, radiator, front clip, etc.) and then you have to disassemble the timing stuff. To R&R the timing chain, by the book, it's 6.2 hours. I can see that as it took me almost 3 hours to just rip the front of the car apart and I've never done it before nor did I have a manual on this car. Someone who is more familiar could save 30mins I'm sure on that alone leaving the time needed to R&R the chain and components.
    As I mentioned above, you're looking at like $700 in labor, at least. If it's a 'full' replacement of all timing (see notes below), you're looking at $1000 in just parts alone. That's still less than $2000 then.
    Depends on what kit. As I mentioned above, I would highly recommend anyone to just swap all of those internals out. On ECS's site, here is the ultimate kit:
    https://www.ecstuning.com/Audi-B8_A4...ing/ES2592683/ - $653
    That kit does not include a front timing cover, which I will almost guarentee will get bent upon removal (see my thread on why); new cover:
    https://www.ecstuning.com/Audi-B8_A4....0T/ES2737581/ - $140
    and the kit doesn't include the oil pump chain and tensioner:
    https://www.ecstuning.com/Audi-B8_A4....0T/ES2224492/ - $85
    https://www.ecstuning.com/Audi-B8_A4...2.0T/ES281409/ - $31
    All of that is just over $900 and you'll need to get the proper sealant stuff with is like $70 alone
    https://www.ecstuning.com/Audi-B8_A4...2.0T/ES463634/
    There's a $1000 basically right there.
    Quote Originally Posted by van462 View Post
    Correct; as I mentioned above, the tensioner has been revised like 6 times already and the newer style chain has beefier links.
    I'm not sure why you guys are calling it a 'cam bridge', its the control valve for the intake cam. T10352 removes this. You are correct on that there are 2 different models, T10352 & T10352/1. The kit I mentioned earlier, the part has BOTH versions on the same tool which is actually the T10352/1 (which is very nice). How many miles did you have on the motor when you did your swap? It's possible you may not have had much wear on the guides. Having said that, the timing guides have been revised as well. That black RTV would be a good recommendation; however, it will eventually breakdown with the PCV gases and you might get some oil seapage. I posted a link above on the 'VW' proper sealant that is used on the front cover. The timing locks really help 'hold' everything in place when you re-establish timing.
    Quote Originally Posted by jfo View Post
    I've covered much of which you've stated to above, so I won't repeat. Based on my findings, the chains that do break seem to break because it catches that oil drain gutter in the front cover since there's so much slack in the chain when you start the car. It literally jumps like a bike chain.
    T10368 hasn't been replaced at all. T10368 doesn't hold timing - it's meant to protect the front splines on the crank's face where the crank pulley bolts into. Timing shouldn't jump at all if you follow the procedure properly. I do not show any details for T10351.
    This is why you use T10368 to maintain pressure against the whole assembly as well to protect the crank's splines.
    Here is a pic of the timing in a CAEB motor (from the thread I mentioned):
    - The front most chain, which goes to the bottom, is for the oil pump. It has it's own tensioner; pictured in most foreground, lower right. I posted details on this above. The oil pan has to come off to replace this chain.
    - The main timing chain is then next and rides on the main timing guide (in the picture its the black guide rail on the left). This goes around the crank and up and around each cam's sprockets
    - The 3rd chain is behind the main timing one and that's for the balance shaft. You can see its guides for it, almost placed horizontally and that timing chain has its own tensioner which is more static (you can see it just below the POS tensioner that is prone to failure).
    Quote Originally Posted by A4 Centaur View Post
    See my previous responses - ideally, you might as well do them all if you're in there and want a good piece of mind.
    Build Thread
    Jun 12 2013
    Quote Originally Posted by Lambda13 View Post
    Ya know, I've thought about it and I probably would be willing to do something like that. I think I posted it in a different thread too when someone asked me. Maybe something like you PayPal me $200, I ship the tools to you, keep them for as long as you need, ship them back to me and as long as they aren't screwed up, damaged, etc. I'll refund like $170 back to ya... Something like that.
    Key word there is "minimum". As I stated earlier, ALL of these parts wear together. If you plan on keeping the car, I highly suggest to just do it all since you or who ever you have do it to swap it all out. You really don't want to mess around with it again.
    Build Thread
    Sep 24 2014
    Central NJ
    S4'ed : T10368 has been replaced with T10351. The old tool often failed to maintain the sprocket timing : when the crank pulley center bolt is removed, the timing often jumps before you can install the T10368.
    Alowencer : T10368 hasn't been replaced at all. T10368 doesn't hold timing - it's meant to protect the front splines on the crank's face where the crank pulley bolts into. Timing shouldn't jump at all if you follow the procedure properly. I do not show any details for T10351.
    S4'ed : The latest VW Factory Service manual has revised the crank pulley removal procedure to now replace the T10368 tool with the new T10351 tool because mis-timing issues can and do sometimes happen if the old tool is used, even if you follow the old procedure. The new tool holds the splined crank sprockets clamped together, 100% of the time, the old T10368 tool does NOT, and that's when the sprockets sometimes can jump out of rotational timing alignment due to the rotational forces on the camshaft due to valve spring pressure on one or more cam lobe ramps.
    For tool T10351, see ecstuning.com, item number ES#2992110
    Nov 17 2010
    I couldn't find this tool either. You have the number mixed up..it's T10531.
    2011 A4 Avant
    Jun 12 2013
    T10531 is not for our motor gents (not for the CAEB).
    Aug 14 2010
    wisconsin
    Just wanted to update on my progress with this, just in case anyone else is interested in doing this via shop. I've decided to have a very good reputable shop in my area do this work for me, they specialize in Audi and they have done a few of these already, i ordered all the parts from Audi at my dealership cost of about 450 which was the main chain, tensioner, the 3 chain guides, all the seals and bolts, along with that price i got a new alternator belt, belt tensioner and pulley to be swapped out while they are in there. There cost to install all of my parts is $680 and they guarantee there work for 1 year. I hope this helps anyone have any idea if i should go about replacing anything else while the stuff is apart?
    Jun 12 2013
    Good choice and that seems to be a very fair price on all of it. Good luck!
    Build Thread
    Aug 14 2010
    wisconsin
    thanks everyone for all your help.
