Results 1 to 6 of 6
    Veteran Member Three Rings JHousyS4's Avatar
    May 09 2004
    2001 Black Audi S4 6 Speed
    Exclamation HELP! BRAKE Light / ABS popping on
    Hi Team!
    Was working on the rear tail light mod and realized i didn't have the right tool to make the hole for the passenger side fog light. So after taking everything down, I put it back together.
    I checked the brake fluid afterwards...looked good.
    Now, when I start the car, its fine...BUT when I turn on the light switch, the cluster reads: BRAKE LIGHT. The ESP Triangle pops on as well as ABS.
    I am also noticing the rear reverse lights aren't working...
    What the hell is going on!
    HELP.
    Jonathan
    May 09 2004
    Did some snooping around...had some bulbs in the wrong socket..no more BRAKE LIGHT, but ABS and ESP traction pops on...i was messing with the Brake Fluid earlier...tapping it to see if there was any in there, could have messed with the sensor.
    I still don't have reverse lights...hmmm
    Aug 17 2015
    Holland
    If one sensor fails, the complete ABS/ESP fails on any 2.7t audi. This means that ABS/ESP is disabled, and you really should fix that stuff. Audi's ABS/ESP is a life saver.
    2001, RS4 B5.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    You even vagcom, bro?
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Veteran Member Three Rings Kenrevo's Avatar
    Aug 05 2013
    MA
    Like zillarob kinda said, you really need vag com to see what the issue is.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    '01.5 S4 F21 on meth -- DD
    '05 Touareg V8, loaded
    '00 A4 1.8t Avant SOLD
    '99.5 A4 2.8l 30v QMS SOLD
    May 09 2004
    I shorted the fuse in the tail lights...
    we fixed the sensor but ABS ESP still popping up
