Results 1 to 3 of 3
    Senior Member Three Rings A4F3V3R's Avatar
    Sep 15 2010
    Québec, Canada
    Windows and sunroof not working
    Hi guys i have a problem with my 1998 audi a4. The windows and the sunroof won't work from inside the car (with the buttons) but if i use the key to lock/unlock the car and hold it all four windows will go up and down. I don't get it. Any idea?
    Sorry if you have a hard time understanding im french canadian. eh.
    '98 A4 on basic mods
    FMIC - Neuspeed chip - Test pipe - cone filter + custom heatshield
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Bad switch?
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    Ground # 900 provides the signal for all of the switches in the system other than (i assume) when the central locking module commands their action.
    If you need a wiring diagram you can PM me and I'll see if I can get you one.
    Id start by checking the resistance between G900 (bottom of left a pillar; brown wire) and the neg battery terminal.
    If you don't want to deal with the trim by the pillar you could also check for ground at pin6 on a front window motor connector (also brown wire).
