Originally Posted by
JimmyBones
Yeah the pin inside the mechanical camshaft adjuster. Jason@JHM goes over the parts and how to do the mechanical camshaft adjuster rebuild in a video if you or your mechanic isn't sure about things.
Replace the connector. I don't like to break stuff because it is an extra step to deal with.
No problem.
okay!! so my mechanic attempted to put my s4 in TDC today. And he said its out of time. Which tells me the car skipped timing, and probably has a broken guide. He said he would do the engine pull for $1,000.00.
My other option is bring it to a reputable shop that has done a bunch of these, and have them do it. I talked to them, and they said unless I buy a kit that includes OEM adjusters, and new Electronic adjusters. They will NOT do it. For liability reasons... I already ordered the JHM Cam adjuster sprockets. So I could perform the rebuilt. This particular shop said its better to buy new OEM ones. I thought the the JHM ones are made better, and last longer... Correct me if im wrong please!
Anyways. That place quoted me $2500 labor to do everything. Including head gaskets, valve stem seals, and cleaning the heads.. (timing chain guides also of course) But they want me to spend 4k on parts alone.. 90 days warranty...
I just wanted people opinion.
thank you
