Results 1 to 8 of 8
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Faults - misfires
    A friend was teaching his son to drive stick on his '04 vert. His son stalled it and it wouldn't start. I cleared the codes and was able to start it. Runs really rough like not all cylinders are firing.
    Could this be a coil? And does it make sense that a coil would pop from stalling?
    Address 01: Engine Labels: 079-910-560-BBK.lbl
    Part No SW: 8H0 910 560 B HW: 8E0 907 560
    Component: 4.2L V8/5V G 0010
    Coding: 0007714
    Shop #: WSC 00672 785 00200
    VCID: 2756777095327E060A-5102
    7 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 -
    16688 - Cylinder 4
    P0304 - 001 - Misfire Detected
    16687 - Cylinder 3
    P0303 - 001 - Misfire Detected
    16395 - Bank 1: Camshaft A (Intake)
    P0011 - 008 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
    16890 - Idle Control System
    P0506 - 002 - RPM Lower than Expected - Intermittent
    18010 - Power Supply Terminal 30
    P1602 - 002 - Voltage too Low - Intermittent
    16685 - Cylinder 1
    P0301 - 001 - Misfire Detected
    Readiness: 0000 0000
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    or bended valves due to timing guide failure .
    May 03 2009
    East
    Quote Originally Posted by xhackerekx View Post
    Shit, didn't even think of that. Think he had the chain done, which I assume would include the guides. Will find out. Unfortunately, it makes more sense than a coil blowing from stalling.
    May 03 2009
    East
    Would there likely be chain rattle before failure?
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Get the engine running at idle and look at measuring value blocks 15-16-17. That way we can see which cylinders are misfiring. There are fault codes for cylinder 1-3 and camshaft over-advanced for bank 1. It would also be good to go into measuring value block 94 as well.
    I would be looking at a vacuum leak or a camshaft adjuster issue.
    May 03 2009
    East
    Quote Originally Posted by JimmyBones View Post
    Cool. Thank you! To measure a block, would I just go into the screen below and enter the block numbers in the far left field? Haven't done this before.
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by B-Time View Post
    [IMG]http://www.ross-tech.com/vag-com/tour/704-screens/meas_blocks.png[/IMG
    Yes. Put the block number into the far left field and click "Go!" or press enter.
    May 03 2009
    East
    Thank you for your time! Much appreciated.
