Hi, have problems with my friends car! Loss off power
Any help would be appreciated?
Thanks
Chassis Type: 4G (4G0)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62 72
VIN: WAUZZZ4G1CN137137 Mileage: 164499km-102214miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CGLC) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 LA HW: 03L 906 018 JL
Component: R4 2,0L EDC H24 2023
Revision: 45H24---
Coding: 12194012242401080000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_EC2M0TDI01103L906018LA 003009
ROD: N/A
VCID: 74E044FFDFA8889E49-8020
No ASAM data for: "EV_EC2M0TDI01103L906018LA" (AU57)
3 Faults Found:
4881 - ROD - Unknown Error Code
- 00 [168]
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 119
Mileage: 164162 km
Date: 2016.02.10
Time: 18:38:37
4891 - ROD - Unknown Error Code
- 00 [237]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 33
Mileage: 164162 km
Date: 2016.02.10
Time: 18:39:12
4892 - ROD - Unknown Error Code
- 00 [237]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Mileage: 164162 km
Date: 2016.02.10
Time: 18:39:11
Readiness: 1 3 0 0 0
Address 03: ABS Brakes (J104) Labels: 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 06A087016005E1809B00
ASAM Dataset: EV_EPSPremiAU57X 004028
ROD: N/A
VCID: 3664BEF78954DA8EB7-8062
No ASAM data for: "EV_EPSPremiAU57X" (AU57)
3 Faults Found:
0606 - ROD - Unknown Error Code
- 00 [008]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 163690 km
Date: 2016.02.02
Time: 19:50:20
0607 - ROD - Unknown Error Code
- 00 [008]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 163690 km
Date: 2016.02.02
Time: 19:50:20
0787 - ROD - Unknown Error Code
- 00 [008]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 147
Mileage: 163428 km
Date: 2016.01.30
Time: 20:15:01
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BN HW: 4H0 907 064 BN
Component: BCM2 2.0 H31 0333
Revision: 00002001
Coding: 03B93006000000000000
VCID: 76E47EF7C1D49A8E77-8022
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
No fault code found.
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 G HW: 4G0 820 043 G
Component: KLIMA 2 ZONEN H10 0064
Serial number: 19021200040503
Coding: 34220008A0
ASAM Dataset: EV_AirCondiBsaisUDS 002040
ROD: N/A
VCID: 234277A32AC65F2660-8076
No ASAM data for: "EV_AirCondiBsaisUDS" (AU57)
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 4H0 907 063 BM HW: 4H0 907 063 E
Component: BCM1 2.0 H12 0111
Revision: 19012002 Serial number: 00000001232347
Coding: 2600201040349F600481008000001D0C0F9D87082709010100 0004602100
VCID: 74E044FFD7A8889E49-8020
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 120127 H35 0080
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 N HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0050
Revision: 11001001 Serial number: 55901204401504
Coding: 080208
ASAM Dataset: EV_EPHVA18AU75X0000 002005
ROD: N/A
VCID: 3D76A1DBAC6209D676-8068
No ASAM data for: "EV_EPHVA18AU75X0000" (AU57)
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG0074HL1
Coding: 30323436313230303235554A305234473053
ASAM Dataset: EV_AirbaAU01BPAAU64X 001014
ROD: N/A
Subsystem 1 - Serial number: 3575HRB404R131GQ3PGT
Subsystem 2 - Serial number: 3585HRB406512NLC39B1
Subsystem 3 - Serial number: 3515JRB404V0P3T48108
Subsystem 4 - Serial number: 3525JRB40530P3T4IOGV
Subsystem 5 - Serial number: 3554VRB405514KDM08UQ
Subsystem 6 - Serial number: 3564VRB405514KDM7GDP
No ASAM data for: "EV_AirbaAU01BPAAU64X" (AU57)
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20120221001030
Coding: 000015
VCID: 306888EF6330F4BEED-8064
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H08 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 950 K HW: 4G8 920 950 K
Component: MDieGb H34 0209
Revision: 26450208 Serial number: 658120212592056
Coding: 33A410000B012600010000
ASAM Dataset: EV_RBC7KMID 004045
ROD: EV_RBC7KMID.rod
VCID: 377AB3F38E5E2386AC-8062
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000408370
Coding: 00CD074400
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 346084FF9F28C89E89-8060
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790966063
Voltage stabilizer:
1 Fault Found:
12291 - Energy Management Active
U140B 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 17
Reset counter: 171
Mileage: 160928 km
Date: 2015.12.25
Time: 07:14:12
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 HW: 4G0 907 637
Component: SARA 3D H02 0009
Revision: -------- Serial number: EJ1BPA3201GPLJ0
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SRAA 009017
ROD: N/A
VCID: 6BD25F838296576698-803E
No ASAM data for: "EV_SRAA" (AU57)
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011C16204001620002080002
VCID: 428CD227DD9C762E0B-8016
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0006360126
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
VCID: 326C82E7653CC6AE9B-8066
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0170320417
Coding: 013B062220B904408320090400010400000000000000000000 0000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 418EDD2BD89A6D3612-8014
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000254746
ASAM Dataset: EV_ParkiRbake 001022
ROD: N/A
VCID: 2A5C9A874DEC8E6E23-807E
No ASAM data for: "EV_ParkiRbake" (AU57)
1 Fault Found:
464384 - ROD - Unknown Error Code
- 00 [008]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 147
Mileage: 163428 km
Date: 2016.01.30
Time: 20:15:01
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 120217-0004-070
Coding: 112296101000A300
ASAM Dataset: EV_HedalRegulBasic 005001
ROD: N/A
VCID: 2C509C9F4718905ED1-8078
No ASAM data for: "EV_HedalRegulBasic" (AU57)
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4G0 035 193 E HW: 4G0 035 193 D
Component: RMC Cnct Nav H52 0775
Coding: 0101010101415B47002B060301010000010000
VCID: 254669BB2CF2A1160E-8070
Subsystem 1 - Part No: 8X0 919 884 D
Component: P13-50-11.06 0002
Subsystem 2 - Part No SW: 4G0 919 603 HW: 4G0 919 603
Component: DU6 Basic H42 0084
Subsystem 3 - Part No SW: 4G2 919 710 B HW: 4G2 919 710 B
Component: E380 BDT C7 H11 0204
2 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 68
Mileage: 154814 km
Time Indication: 0
Date: 2015.10.22
Time: 15:37:25
03787 - Rotation Mechanism for Display Module Front
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 4
Fault Frequency: 5
Reset counter: 155
Mileage: 163603 km
Time Indication: 0
Date: 2016.02.01
Time: 20:13:41
Freeze Frame:
Voltage: 13.60 V
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010814204001620002080002
VCID: 4480D43FC788781E39-8010
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H04 0212
End-------------------------(Elapsed Time: 04:38)--------------------------
Second scan after clearing
Address 01: Engine
3 Faults Found:
4881 - EGR Valve (N18)
P1440 00 [038] - Open Circuit
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 164499 km
Date: 2016.02.13
Time: 16:53:55
4891 - EGR Valve (N18)
P0403 00 [039] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 164499 km
Date: 2016.02.13
Time: 16:52:17
4892 - EGR Valve (N18)
P0403 00 [167] - Malfunction
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 164499 km
Date: 2016.02.13
Time: 16:53:53
Readiness: 0 0 0 0 1
