Results 1 to 10 of 10
    Jul 04 2012
    Woodbridge, VA
    Shifter doesn't go back to middle
    I bought this car a couple weeks ago. The PRev owner said he has a JHM short shifter with Delrin bushings. My other s4 has just the short shifter and it doesn't have issues "coming back to center". Moving from side to side it will just stay there. I don't remember there being a spring mechanism inside the short shifter (besides reverse). So how does it spring back to center when going in neutral???
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    its spring loaded by a detent on the transmission which loads the selector shaft. JHM makes a modified detent that compresses the spring and makes it harder to go side to side.. I'm going to be ordering one soon
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Oct 27 2014
    Flag/Phx, AZ
    Here's a pic of it
    IG: CJ_s4
    Jul 04 2012
    Woodbridge, VA
    Interesting. The spring in the detent is just worn? Thanks I'll look into this
    Oct 27 2014
    Flag/Phx, AZ
    Im assuming thats the issue. Not quite sure if they're a common wear item or common to break, but thats the only thing thats spring loaded for neutral
    IG: CJ_s4
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    detents only hold the forks from coming out of gear. once through the detent the shift collar/syncho assembly is what is supposed force it back to center.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Naw, those detents only handle forward/backward.
    Side to side is the the thing in the jhm pic above.
    That one rides in a V-notch on the selector shaft and gets compressed by the sides of the V when you go left/right.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by zillarob View Post
    Any idea of how accessible the detent is with the tranny in car?
    Oct 27 2014
    Flag/Phx, AZ
    WHERE DOES IT GO? This upgraded detent-centering spring installs in the transmission near the selector shaft cover. This is best done with the transmission out of the car, but can be done (with some difficulty) by just lowering the trans and engine down in the rear)
    Thats from JHMs website, not sure if they include instructions or not.
    IG: CJ_s4
    Nov 16 2010
    WetSide, WA
    That one prob isnt too tough to get to. Its a 27mm iirc so finding a tool that fits in there will prob be the hard part.
    Ive swapped them all before and nothing stands out so must not have been that bad.
