Results 1 to 16 of 16
    Active Member Two Rings apexi's Avatar
    Dec 14 2015
    YVR
    Rotating tires (TPMS)
    Has anyone rotated their tires with TPMS sensors installed? Wondering if there is any need to recode through VAGCOM or if it'll auto relearn the wheel positions using the "store tire pressure" through MMI menu?
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    What car do you have?
    Active Member Two Rings JayNana's Avatar
    Dec 21 2015
    London
    As I've learnt here TPMS works via wheel speed sensors also used for traction control, ABS. There are no 'TPMS sensors'.
    Also I remember reading in the manual - it recommends rotating tyres (mindful of tyre rotation direction), no mention of any TPMS concerns.
    Also the typical user would not have access to VAGCOM to complete a procedure recommended in the user manual.
    Ie. You're totally safe to do it, if the front-rear tyre pressures are different TPMS may get annoyed, just reset it.
    Dec 14 2015
    YVR
    I have an '16 RS7. On the RS the wheels have individual wireless sensors vs through the ABS. Since each sensor shows the tire pressure and temp for left front, left right, rear left, rear right, was curious if anyone had any experience with rotating tires and having to recode/calibrate the tpms sensors.
    Dec 20 2006
    CAN
    Quote Originally Posted by apexi View Post
    i don't think it really matters if you move the wheels around. i believe the sensors are mated with another local sensor on that particular corner of the vehicle.
    Quote Originally Posted by JayNana View Post
    The RS7 and R8 specifically have TPMS sensors. All other models do not.
    emilyPay.com - Payment Processing for Professionals
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Headliner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Jun 30 2012
    16 Lava Orange GT3 RS, 18 Nardo Grey RS3, 17 Panda Macan GTS, 91 C2 964, 16 F150 Lariat, 63 Impala
    Woodstock GA
    So if I'm getting new wheels on an rs7, do I need to be doing anything with this tpms?
    Dec 20 2006
    CAN
    Quote Originally Posted by tonymission View Post
    Yes.
    Established Member Two Rings VPRS7's Avatar
    Nov 01 2014
    You will need new tpms for each new wheel ~$130 each Otherwise you will get error messages
    When you rotate you just need to reset tire pressures via MMI
    2014 Audi RS7: Daytona Gray / Unitronic Stage 1+ Tune / 21" Corse Werks Agio Monoblock w Michelin PSS / DRC / KW H.A.S. / Eurocode Sways / AWE S-Flo Intake / Sport Exhaust / Carbon Inlay / B&O / VAG mods
    Former: 2012 C63 AMG Coupe, 2012 M3, 2008 M3 Sedan, 2004 M3, 1998 M3 (track-prep), 1998 M3, 1991 M5....
    May 24 2015
    NW
    Or if you skip the sensors, you can use VAGCOM to disable the error message
    Jun 30 2012
    Woodstock GA
    Quote Originally Posted by VPRS7 View Post
    Of course I do; because the wheels aren't expensive enough. :p
    May 08 2004
    NoVA
    Every day I learn why I can't afford a RS7, even if I could afford the purchase price. Why in the world aren't the sensors reusable?
    l Previous: 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l 2025 Rivian R1S Tri l Midnight/Dark Mountain l XPEL Stealth Wrap l
    Jun 05 2008
    Carmel, IN, USA
    So, on the S6, I don't need to buy sensors for my winter wheels, right? Thanks!
    '14 S6 Prestige Phantom Black Pearl Effect/Black: Sport Rear Differential, Head-up Display, Night Vision, Driver Asst Pkg, Contour Seating, LED Headlights, Layered Aluminum/Blk Wood, Sunshades, Cold Weather Pkg, Rear Airbags, Side Tint, Auto Hold, Audi Platinum Protection 12/'21 96,912 mi
    ’13 Mercedes Benz E 550 4Matic
    '16 Honda Odyssey Touring Elite Obsidian Blue Pearl
    Sold: '05 A6 C6 3.2Q Stratos Blue Loaded
    Jan 06 2015
    Kansas City, MO
    I don't know about the RS7 but in general, TPMS can be reused but often need to replace the rubber grommet. They are somewhat fragile though and if you get one that gets bumped wrong, it's a PITA to get figured out. On a $100k+ car and spending extra on wheels, is that really the piece that is going to make or break though? Spend the dough.
    For the question about the S6, no you don't need to worry. There are no sensors...it's all ABS.
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    I also thought the S6 used the ABS sensors, to detect an abnormal wheel rotation. I was surprised that my MY16 S6 said that the tire pressure was in range when I recently set it. I guess they must store the last rolling rate, so they can check it when you set it while stationary.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Nov 01 2014
    Feeling your pain (and having a pretty good chuckle also)🙂
    Dec 14 2015
    YVR
    Rotated my tires criss cross on the RS7 and can confirm that the TPMS module will relearn the new positions. In my case I needed to "clear DTCs" in vag to reset the TPMS module as I had temporarily disabled it for the winter tires.
