Results 1 to 27 of 27
    Sep 12 2014
    Long Island
    High output alternator or something else?
    So I put a decent powered sound system in my car. 1200W RMS Sub amp to two 12" subs and a 400W RMS 4 channel amp to all my doors. So nothing crazy in terms of power but about 1600 watts RMS at most given times.
    All my wiring and setup is proper, meaning 2 gauge wire from my battery terminal to the 30 farad capacitor and then 2 guage from that to both amps so I dont think my problem is in the setup.
    My issue is that when i turn the volume up for the system(remote bass control that turns the gain up and the overall system volume from the head unit) the bass hits very well and doesnt seem to cut out or have any issues but my door speakers just completely stop outputting audio. Like my subs are going crazy but my door speakers arent doing anything at all.
    My question is where do you guys think my problem is. Considering all my wiring is up to spec im thinking it might be my tiny 90 amp factory alternator but Id like to hear opinions from you guys
    Nov 03 2011
    All Over!
    I am positive the alternator isn't the issue. I would be looking at your amplifier.
    Out of interest, are B5 S4 alternators 90 amp units? My 2000 B5 2.8 30V was 120.
    1986 Type 85 Audi 90 quattro
    Dec 10 2013
    Borden, Ontario, Canada
    120amp like the 2.8
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Sep 12 2014
    Long Island
    I actually have a 1.8t in my automobile at the moment so i believe it would be 90 amp, what would be the issue with the amp theyre bothbrand new straight from kicker?
    Senior Member Three Rings Nizmo's Avatar
    Oct 09 2015
    Boston
    Install a Capacitor to the amp circuit. It will at the very least keep the headlights from dimming....
    Nov 03 2011
    All Over!
    Quote Originally Posted by tmaclax013 View Post
    My apologies for digressing here. Is your car a B5 A4 1.8T, or a B5 S4 with a 1.8T installed?? Or are you looking to swap a 2.7T into an A4?
    Veteran Member Four Rings Racin2redline's Avatar
    Aug 19 2012
    1997 Yamaha razz 50 (sik)
    Long island
    largest alternator you can run with the 1.8T is a 120amp. stock is prob 90amp
    2.7T you can get a slightly larger 140amp. don't believe it would fit the 1.8T ?
    Sent from my SM-G900P using Tapatalk
    IG: d3bel1o
    Sep 12 2014
    Long Island
    http://www.qualitypowerauto.com/item_385/Audi-A4.htm 200 amp alternator for the 1.8t
    And for nollywood its currently a 1.8t with intentions of a 4.2 or vr swap but thats for a different thread
    Sep 12 2014
    Long Island
    My thoughts are that the gain on the 4 channel amp is set low as it is and the door speakers only cut out when the bass comes in heavy so Im thinking it has to be a power issue, considering i already have a huge capacitor feeding the amps and the proper wiring
    Aug 19 2012
    Long island
    if your going to do that I'd upgrade the harness wire from the alternator to the battery and put an inline fuse to the panel.
    IG: d3bel1o
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    B5 S4 section would rather quabble about what constitutes an S4 and other serious shit.
    We ain't got no time to help you with your 1.8T's sound system woes.
    Aug 17 2015
    Holland
    You know that certain devices in your car can consume serious amps in order to maintain stability in your car? For example, the ABS unit takes a 30A in order to function best. Why would you put such an audiosetup in your car, and presumable drive around with it and risk power problems to components in your car?
    I'm sure you woud'nt drive your car with full power going on but i'm just saying. Your better off engineer it the right way instead of going for a gamble.
    2001, RS4 B5.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    But the factory ABS sounds like crap, Id much rather listen a nice stereo system
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Sep 12 2014
    Long Island
    Quote Originally Posted by Jism View Post
    So what exactly would be considered "engineering it the right way"?
    Apr 16 2013
    Colorado
    capacitors don't do shit, it's just a bandaid on a bigger problem. Check your wiring. I'm running a 600w rms 4 channel amp and a 600w rms mono amp for my sub in my 2.7. No capacitor and no problems.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    you can get whatever you want. look for a local place that will rebuild starters and alternators, bring them whatever you have on the car and ask for it to be a higher output.
    we've done this locally with many of out diesel semis, to run more lights without killing the electrical system.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Sep 12 2014
    Long Island
    Other thing is that Im getting headlight dimming when the subs are loud, even with a capacitor, thats what leads me to believe its a power production issue
    Aug 04 2013
    Pennsylvania
    I'm not an audio expert by any means but have you considered putting a second battery in your trunk?
    Back in the day I had a T15001-bd powering two T1 12's and my lights would practically shut off when the bass would hit and I also had issues with the amp's thermal protection constantly shutting it off.
    Once I put a second battery in the trunk all was well. I was also advised that capacitors don't do much except look cool.
    I'm like a tree. I'm all root
    Veteran Member Three Rings Chris_s1's Avatar
    Apr 07 2014
    Miami
    Caps are worthless, waste of money. You could upgrade alternator or battery and I'm sure it wouldn't hurt. What brand door speakers and amps do you have? I've had a sound system on every car I've owned and never used a high output alternator, nor have I used a cap. How positive are you that it isn't a wiring problem?
    Clarify for me... you've got an a4 you're looking to swap a 4.2 into or you've got an S4 you swapped a 1.8t into??
    2000 2.7t 6 Speed Build in Progress...
    Sep 12 2014
    Long Island
    6.5" Kicker KS component speakers in all 4 doors
    2 12" Kicker Comp RT(Shallow mount) Subwoofers
    Kicker CS 1200w Monoblock Amp
    Kicker KX400.4 4 channel Amp
    Pretty confident that my wiring from the battery isnt the issue. Its pretty much 2 Gauge wire from the battery all the way to the amps.
    And for everybody whose asking its currently a 1.8t A4 with plans of a 4.2 swap most likely
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    Quote Originally Posted by Chris_s1 View Post
    my 1.8t used to dim when my subs hit hard it was a 2000w amp. but the 1.8 is small so any real extra power draw it will notice.
    White 07 Q7
    Sep 12 2014
    Long Island
    Quote Originally Posted by audacity View Post
    Well thats why I am thinkig it might be the alternator. Because if I have headlight dim it means there isn't enough current to constantly feed the cars electronic draws. So my door speakers cutting out is a result of lack of current
    Aug 17 2015
    Holland
    Larger alternator, larger battery. A capacitor is only there to take away any fluctuations in voltage. For example, if you would turn on your set instant at loud volume, it would snoop the voltage down from 13.8v to 11v for a second. A capacitor would 'solve' that issue. It's not solving an amp issue.
    I'm sure it woud'nt cause problems in this way but i woud'nt put things in a gamble either.
    2001, RS4 B5.
    Sep 12 2014
    Long Island
    Well my general question in this thread was whether or not i need a higher powered alternator, and some people are saying yes and some people are saying no, so I'm trying to figure out what exactly constitutes being "engineered properly"
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Sometime the speakers will shut off
    when there is too many watts bring
    fed to them then they could handle.
    Check what your door speaker are rated
    at RMS wise and then check your amp.
    Also how they were wired bridged or not
    4 ohm to 2 ohm ETC.
    Aug 17 2015
    Holland
    Get a higher alternator, or second battery for the trunk. That would basicly solve your issue. Cheapest way is a second battery.
    2001, RS4 B5.
    May 20 2012
    San Jose
    If the 1200W sub amp is playing loud and clean, you've got enough current coming from the alternator. I'd be looking at the power feed to the 4 channel amp and whether that amp's protection circuit is kicking in at high volume.
