Results 1 to 6 of 6
    Established Member Two Rings rtk8892's Avatar
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    How to wire in stereo without plug and play harness?
    Hello everyone I drive a b6 s4 and have the bose system. I recently purchased a pioneer avic120bt and want to install it but I can't find the right harnesses for the plug and play. I pulled out the stock radio and there's two wire harnesses, and two antenna plugs. I don't need radio right away, but would love it if someone would provide me instructions on how to hardwire the new radio in. I don't know what wire is what and help would be great. Thanks!
    Sep 16 2010
    Central Wash
    Don't do it. You should get a 'pigtail' or adapter harness for aftermarket stereos, for your car specifically. Do NOT cut the wires/ quadlock connector off from the cars harness, you'll regret it.
    You want some variety of a thing like this:
    Clickity Harnessy Clickery
    That you plug into the chassis harness and it leaves you with wires to splice your stereo to. Likely need to add RCA or other connections for your config. There are better ones out there, but it's a start. But..don't CUT the cars wiring.
    Also need a version of the antenna adapter- for what it's worth. Unless you live in a city with GREAT radio stations and powerful signal you will lose MOST of your radio reception.
    Jan 10 2007
    VA
    I concur.
    Just get the harnesses. With my B6 I got mine from Crutchfield. All you have to do is wire the harness to the aftermarket head unit based on the wiring diagram that comes with it. Then it just plugs in directly to the Audi harness. Real simple and easily reversible.
    Check the forum for threads on installing an aftermarket head unit in a B6/B7. Its more complex than most. You also need a trim kit, mounting bracket/cage, etc to do a full install.
    May 29 2010
    2004 Audi S4, 2008 Audi RS4 Ti
    Phildelphia / Auckland
    I didn't like that the crutchfield harness was not 100% PnP. You still have to bring over a power wire.
    If you get the right combination of Enfig adapters, it's 100% PnP. You just have to make room for all the extra bulk and radio depth since there's an HVAC duct behind the radio.
    http://enfigcarstereo.com/audi_radio_installation.html
    Nov 23 2010
    2015 A4 Premium Plus
    Lake Stevens, WA
    Here are couple other radio replacement interfaces from Pac-Audio that work very well.
    C2R-AUDI
    RP4-AD11
    Veteran Member Four Rings MugelloB7RS4's Avatar
    Feb 06 2015
    Quote Originally Posted by S4Bennett View Post
    X2. I used Enfig to install my AVIC8100-NEX and it was 100% PnP. No cutting, no crimping, no soldering. It was all done for me and ready to go. I told them what vehicle, what options and they supplied me with everything I need. I would go with them again in a heartbeat just for simplicity sake.
