Results 1 to 7 of 7
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Red face Something I should know but don't.....
    Does the S (sport) mode vs D mode alter the stability control to allow for more tail wag?
    Just curious what else it impacts besides throttle response.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Three Rings carlosvjr92's Avatar
    Nov 25 2015
    Miami, FL
    Pretty sure it just holds the RPMs higher
    2018 RS3 (Cumulus Blue) - APR Stage 2 || APR Intake || APR Downpipe
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    I think S is the same as setting the engine to dyamic via ADS. It will modify rpms and hold gears longer, and I think is required as the first step to use launch control; however, S will not modify steering/suspension/sport diff/engine sound. For those you would need to select dynamic in the drive select. So you can either go full dynamic mode on all systems via ADS, or just the engine by switching it into S...my observations at least.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    No, but you can alter that with your sport diff settings, assuming your car has a sport dif. More stability control will give you less tail wag. Auto will be defualt. Comfort will give you less stability and Dynamic will give you more. Not adjustable without sport dif.
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by Dr GP View Post
    I'm confused by staying comfort will give less stability and dynamic more?
    Dec 07 2014
    Mn
    Just turn your esc off and your problem is solved.
    Sent from my LG-H901 using Tapatalk
    2014 S4 DSG///Unitronic Stage 2+.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    From what I have read sport diff is more stable with Comfort setting.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
