Results 1 to 8 of 8
    Jun 24 2014
    Ctrl. FLA
    Exclamation Fuel Door Locked. Suggestions?
    I have a 2001.5 B5 S4 and from what I've gathered the central locking pump has gone bad. I have been unlocking the drivers door with the key and just recently realized while attempting to fuel up that the fuel door is in the locked position. I've attempted to locate a manual over ride for unlocking the fuel door. My search in the trunk has uncovered nothing. Any help is greatly appreciated. Thanks for looking.
    Jul 04 2012
    Woodbridge, VA
    I have not done this or even looked at how the hoses are run. This is just an idea:
    Gain access to the vac hose from the trunk where the pump is. Place a vac pump on the line going to the fuel door.
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Pull back the carpet on the inside of the trunk where the fuel door is and find the locking rod and slide it back towards the rear of the car. Like you I found out the hard way when I went to fuel up one day and my central locking pump went out.
    1998.5 A4 1.8TQM My Build
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    just pull the actuator off the mount.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Established Member Two Rings SteveAudi99's Avatar
    Jun 28 2013
    ontario
    Quote Originally Posted by xdewaynex View Post
    Sadly this happened to me before as well but had to access the trunk through the car to pop the trunk first. Pretty easy once you're in.
    Jun 24 2014
    Ctrl. FLA
    Pulled back all the carpet on the passenger side trunk but I don't see anywhere to access the fuel door. Is it possible to get a more detailed account on how you were able to access the fuel door locking rod?
    Veteran Member Three Rings achb5's Avatar
    Feb 06 2009
    2001.5 S4 QM
    santa fe NM
    this is the actuator you want to remove, you will probably just see the back of it where the air line goes in
    Jun 24 2014
    Ctrl. FLA
    Once I pulled the actuator I was able to open the fuel door. I didn't realize that the actuator acts as the pin the keep the fuel door "locked". Thank you for all your help everyone. I greatly appreciate it. :D
