Results 1 to 12 of 12
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Re-installing fuel pump basket
    Does anyone else have trouble with this? I can not figure out for the life of me how to get it back in. Its a walbro 450 with the orings in the stock basket.
    I get it to where I think its sitting right, turn it as hard as I can, then it just pops right back out.
    Im not sure if maybe my pump is sitting too low and not letting the basket go all the way down? anyone have a problem like this?
    Should the basket just drop right down and spin pretty easily to where its locked?
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    It's a bitch to do it with your hand in the tank. keep trying and you'll get it, just make sure that your lugs are lined up correctly and that you are keeping the basket flat while turning
    Aug 06 2008
    Canadia
    Aftermarket or OEM basket? Reason I ask I was dicking around for an hour before I realized the basket I had wasn't probably a cheap eBay one and was 1-2mm smaller diameter, I got it in place turned it then it would "pop" out; it wasn't popping out it was just riding over the ridge.
    If it's an OEM basket take the pump out figure out how the basket fits then make some reference marks and try reinstalling
    the B5 S4 is like the mafia... there is only one way out!
    Oct 27 2014
    Flag/Phx, AZ
    I got it, finally.. Took about an hour or two of playing with it. Once I got it seated correctly, it just turned right in. Quite the frustrating task, anyways, thanks for the help!
    IG: CJ_s4
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    They can be a puzzle sometimes.
    The fun begins when you turn the key and it doesnt start because the wires are backward and/or the cap is still on the pump
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    I used the advice I found here about wearing a heavy leather work glove. It made it easier to twist the basket without it cutting into your hands, etc.
    Dec 05 2007
    The basket only goes back in one way. The grooved slots are not spaced symetrical, though they look it. I also took the advice of others and shaved down the slot a bit, to make removal easier next time around. But yeah, working with the pump assembly at times can prove to be a chore.
    Aug 04 2013
    Pennsylvania
    The special pump tool makes things easier. I got a free loaner with mine and was very happy to have it. I still think our pump setup is dumb though. Idk what was wrong with a spring-loaded assembly and a locking collar.
    And red being positive lol
    I'm like a tree. I'm all root
    Established Member Two Rings Dfloods4's Avatar
    Dec 10 2013
    Menifee Ca
    I am right in the middle of getting an 044 back in tank. Life def sucks right now.
    Nov 16 2010
    WetSide, WA
    Deep breaths make it more funner
    Veteran Member Four Rings Racin2redline's Avatar
    Aug 19 2012
    1997 Yamaha razz 50 (sik)
    Long island
    just did this a few weeks ago... in the snow, temp dropping rapidly and my gloves melted. was very fun. took an hour to get the damn thing clicked in
    HATE THAT DESIGN the key is definitely to keep it level and lign the clips up
    Sent from my SM-G900P using Tapatalk
    IG: d3bel1o
    Sep 11 2009
    NE
    This. Keep rotating the basket until you hit the right position and it snap very easily in.
