Originally Posted by
VeeDubbinJetta
How high does this get the bottom of the car off the ground? I've been looking for a solution to do a clutch on my mustang that doesn't involve a full size lift. Unfortunately a regular jack and jack stands won't get it high enough
The BL-3500 SLX specs are as follows:
Platform lifting height (Frame only) - 16.5” / 419 mm.
Platform lifting height (with small rubber block) - 17” / 432 mm.
Platform lifting height (with tall rubber block) - 18.5” / 470 mm.
Platform lifting height (with stacked rubber blocks) - 20” / 508 mm.
The BL-5000SLX specs are as follows:
Platform lifting height (Frame only) - 17.2” / 437 mm.
Platform lifting height (with small rubber block) - 17.8” / 452 mm.
Platform lifting height (with tall rubber block) - 19” / 483 mm.
Platform lifting height (with stacked rubber blocks) - 22.5” / 572 mm.
The BL-7000SLX (with SUV adapters) specs are as follows:
Platform lifting height (Frame only) - 17.7” / 450 mm.
Platform lifting height (with small rubber block) - 18.2” / 462 mm.
Platform lifting height (with tall rubber block) - 19.2” / 488 mm.
Platform lifting height (with stacked rubber blocks) - 21.2” / 538 mm.
SUV adapters will give you added height of 3". These can be added to the 3500 and 5000. Let me know if you have any other questions.
