Tuned 1.8>2.8
Seriously though, don't even try to talk down the pain in the ass that a B5S4 will be.
You need either a disposable income or a strong passion and mechanical ability to own one and expect to rely on it.
We're just trying to let you know what you are getting yourself into.
For reference, I spent 8k on mine last year, it has been very reliable IMO, but it would have stranded me a couple times if I didn't know how to diagnose and turn a wrench on the fly.
-Torn throttle body boot, or clear blown off.
-Starter failure after filling up.
Also had:
- wheel bearing go bad
- Diverter valve failure
- (2) MAF replacements (replaced OEM for ~$300)
- Downpipe flex pipe ripped apart
- Motor mounts split in half
- Brake booster hose split
- Countless boost leaks that needed located and repaired on the side of the road.
- Couple torn CV boots
- Timing belt/water pump
Need to do list:
-Valve cover gaskets
-Control arms
All this was on a car with 123k and a stack of maintenance records adding up to the original owner damn near buying the car twice.
I did do a lot more to it, but that doesn't count because it was a want, not a need. Listed are just required repairs.
Just a heads up, if you have a set limit on the budget, might want to check out the 1.8t. I put together a Avant Quattro 1.8 for a friend with a gt2871 elim, and it was a damn fun car. Looking back I'd say it was on par with a stage 2 s4.
