Results 1 to 16 of 16
    Apr 10 2012
    2003 Audi A4 1.8T Quattro
    Fort Worth,TX
    PSA: Always run throttle body adjustment after ANY intake work
    So I was replacing my injector seats yesterday/today. I got it all put back together and started it up Misfire on cyl 1 then cyl2. I didnt disconnect the throttle body or the battery so was kinda wondering if i needed to do a TBA anyway. I did however clean the IAT sensor. So As kinda a stab in the dark I ran the throttle body adjustment via VCDS. Wham, idle fine, no more misfires. Just thought I would share incase anyone runs into something similar. I am guessing the IAT sensor being cleaned change how much fuel was being added.
    2003 A4 1.8T Quattro Auto, Custom Stage1 tune, N70, 550cc Fuel Injectors, B7 console (with cup holders!)
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Good to know!
    Established Member Two Rings yasiu_k's Avatar
    Mar 24 2015
    Yamaha FZ6
    Did this job 2 weeks ago, I had also misfire right after when I started engine, but only for few seconds. I did not do throtle body alignment. I replaced suction pump, camshaft position sensor and camshaft tensioner. Now works fine.
    Apr 10 2012
    Fort Worth,TX
    Quote Originally Posted by yasiu_k View Post
    mine kept going and wouldnt stop, I was totally befuddled.
    Mar 24 2015
    Yamaha FZ6
    Did you put sealer all around injector seats?
    Sent from my SM-G900V using Tapatalk
    Apr 10 2012
    Fort Worth,TX
    yup, the Loctite thread sealant.
    Mar 24 2015
    Yamaha FZ6
    A lot of things can be wrong. Maybe some piece of old seat went into valves and there is no compression, or just injector went bad, broken wire from injector. That's my ideas.
    Apr 10 2012
    Fort Worth,TX
    everything is running fine now, its after I ran the throttle body adaption that fixed it
    Apr 10 2012
    Fort Worth,TX
    well I am still getting a misfire after I take it out of the drive way, a few of the stupid fuel injector clips that hold the injector on have broken So I guess I gotta replace them
    Mar 24 2015
    Yamaha FZ6
    Get a new ones. They cost few $. Also remember about new injector o-rings. Apply some grease on them, before you install injectors.
    Apr 10 2012
    Fort Worth,TX
    well these injectors are like 2 years old if that, They use the EV6 connector which unlike the stock ones dont have a metal clip to hold them on, they are plastic and totally broken now. I got some coming tomorrow
    Apr 10 2012
    Fort Worth,TX
    I am thinking it has to be that injector connector, because if I let it run in the driveway idling for 20 min it never misses. I drive it down the street and it misses. Must be the vibrations messing with it
    Mar 24 2015
    Yamaha FZ6
    Looks like broken wire.
    Apr 10 2012
    Fort Worth,TX
    redid all of the injector connectors today, so far things are running great.
    Mar 24 2015
    Yamaha FZ6
    Nice;)
    Senior Member Two Rings Phoneboy's Avatar
    Nov 16 2013
    Long Island ny
    I had my throttle body aligned by the dealer due to a misfire. It happens again so they are replacing the throttle body now. Does this make sense?
