Results 1 to 12 of 12
    Jan 07 2015
    Piedmont/CA
    How hard is it to install AWE Quad Exhaust?
    I've got a 2009 A4 B8 with a single outlet exhaust (non sline). When speaking with the normal performance shop that I go to, they laughed at the AWE exhaust being "bolt on" and said they could install it in a couple of hours at $150/hr. They said there's a lot of "adjustments" that need to be done when breaking it in. I'm figuring the shop would factor in 3 hours of labor (maybe more) = 3x150=$450....which seems kinda steep.
    I'm looking at the quad setup from AWE and know that I need the rear valence done as well. I've got ramps, jack, and jack stands. I'm not looking at the resonated downpipe right now (sounds like you need a special tool for this).
    Is this something that I could actually do myself or should I have a professional do it? If a professional needs to do it, I saw some of you post that some shops could install an exhaust setup at $150 total....is this realistic with what I'm looking to get done.
    I've read the DIY, but I don't know what kind of "adjustments" would need to be made when breaking it in.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    The concept is definitely simple and do-able. But the execution is a pain in the ass. The rear muffler section (including y-pipe) is not bolt on - it all consists of slip joints. Getting things lined up perfectly, the way you want, is a headache. Not to mention things will move a bit during break-in, so you have to go back a week or so later and re-adjust things.
    Definitely possible, but its not quite "bolt-on" simple.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    It's not THAT much of a pain....new exhaust pipes go together easy as pie, 4 jack stands 2 hours and a grinder to remove the old one is all you need.
    2016 S3
    Instagram- @Thisisastickup
    Veteran Member Four Rings dennisA4's Avatar
    Jan 13 2006
    Houston
    I think the hardest part about installing a cat back exhaust is having working room. If you have access to a lift it shouldn't be bad at all, but ramps and jack stands don't afford you much room to move/work.
    Doable, just a PITA.
    I'm still curious how hard it is to install JUST the AWE downpipe.
    I already have the rest of the exhaust.
    2014 A4 Prestige Quattro Tip
    Glacier White | S-Line Interior | Sport Package | Window Shades | 35% FormulaOne Tint | V1 Hardwired
    S4 Aluminum Pedals | 19x9.5 Avante Garde M590 | KW V1 Coilovers | AWE Dual Exhaust | ECS Luft-Technik Intake | Unitronic Stage 1+
    Jan 19 2016
    1997 BMW M3 w/ CES Stage IV Turbo, 1999 BMW M3 vert
    Orlando, FL
    Any exhaust that bolts on is relatively simple to install. In a garage on jackstands, it is more difficult. As far as adjustments, you want assemble everything, get the tips oriented were you want and then tighten everything up. Afterwards, check for fitment. I am not too sure about needing make adjustments after break in? Check in a week, tips should be in the same place
    Aug 15 2014
    super easy to install. my local shop quoted $150 for install. IMO, putting my car on jacks, crawling under, fitting it, would probably take me 2-3hours?
    I'd rather just take it to a shop and have them do it while I wait.
    For Sale: Mini Part Out
    Oct 22 2012
    Markham
    paid $100 for my awe catback install and that included some welding too to make it fit
    Jan 07 2015
    Piedmont/CA
    I don't mind paying the $100-200 range for the install. I think I'll need to go somewhere else than my normal shop that charges $150/hour.
    May 07 2014
    The degree of mechanic ability to perform an exhaust installation does not warrant a $150/hr tech. The whole job, on a car like this, should be in that total range, $150 for the job, if it's on a lift.
    2010 A4 2.0t quattro 6mt
    Established Member Two Rings briansubsist's Avatar
    Aug 20 2014
    2016 Audi Q5 3.0 Sline
    Grand Rapids, MI
    I was quoted about $150 from one local dealer and $200 from another. Seems to be pretty consistent.
    Jan 07 2015
    Piedmont/CA
    Anyone have a recommendation for a SF Bay Area shop that could install the exhaust at a decent rate?
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    I got my S4 exhaust done at a small muffler shop in Concord. It was a mid and rear muffler delete, so cutting and welding was involved. I supplied my own tips and ended up paying ~$100 out the door.
    Edit: it was Mel & Son's on Monument.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
