Results 1 to 12 of 12
    Nov 28 2015
    Montreal, QC
    Powerflex TRans mount 2 piece
    Curious to see that no one spoke about this option yet ( or i havent seeen it!). IMO it appears to be a better design for 2 reasons, it's a 2 piece construction instead of 1 piece from the different manufacter billet option and second, it's poly so theres little added noise to the cabin
    http://www.ebay.co.uk/itm/Audi-A4-B8...-/381412161289
    + its about the same price as the other option.
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by waxxonMTL View Post
    We haven't had any issues with NVH transmission from our Billet Aluminum Transmission Mount Insert, and these polyurethane inserts will pack/wear and become ineffective over time. We don't use polyurethane for applications like this, as it's prone to deteriorating with use much faster than rubber or aluminum.
    Hope that helps you make a decision!
    Nov 28 2015
    Montreal, QC
    Quote Originally Posted by 034Motorsport View Post
    Now, I don't want to play cat and mouse, but I've been told directly that the billet mount transmitted NVH and this was also talked a bit in the thread from the latest offering by ECS's mount. Maybe those poly wear too quickly, it's possible. I don't know.
    Thanks for coming by tho ! I'm very much following your ecu tuning developement as I feel your offering will be the best :)
    Sep 17 2005
    Fremont, California
    Just to clarify, the few reports we've had of differential whine transmission have been with a select few cars with the Sport Differential and our Rear Differential Carrier Inserts installed. I honestly can't remember a single instance of the Transmssion Mount Insert resulting in increased NVH in the cabin. It leaves a minimal air gap to prevent any contact at cruise and light load.
    Thank you for the kind words! We're hard at work on both Stage 2 and DSG Software.
    Nov 28 2015
    Montreal, QC
    now that i think about it, it is, in fact, the diff carrier, not the tranny mount ! Keep up the good work, very looking forward to the big announcement. Hopefully for us, a nice intro group buy like EPL did ! :)
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    034 Tranny mount installed. No NVH whatsoever. I also agree that I wouldn't use poly here no matter what. That stuff will just waste away, where it is.
    Oh, and what a difference! It's really great. Need to do the rear diff now LOL.
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    I have the full 034 insert kit and nothing but good things to say about it!
    2021 Audi S4, P34 Intake
    Veteran Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Full insert set here too,no issues to report :)
    I also have the solid engine mounts
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Nov 28 2015
    Montreal, QC
    I understand what your saying guys, but this wasn't a discussion about which product should i buy, but rather one about the second piece that goes under the mount Vs. the solid billet piece. Anyone have thought on rather it should provide more ''support'' to the mount or not ? powerflex, along with energy are well known for their mount so i doubt they would produce a bad quality/useless unit.
    Mar 21 2015
    Same here
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    The only way you would get additional NVH from the 034 inserts,If they were over tightened,helps if you ad a "small" amount of LITHIUM grease upon install,this will help the insert side in easier and get a more accurate torque reading due to less binding/friction.
    I have installed carrier,diff and tranny inserts this way in 4 cars with 0 complaints about any additional NVH.
    Hope this helps!
    Account Terminated Four Rings
    Sep 13 2014
    New York
    I think the powerflex mount is doing it right. Polyurethane is stiffer and less prone to cracking. I'm waiting to see what ECS comes out with. I would run the powerflex without the 034 insert v
